Behringer B2031 speaker just stopped working. Some thuds was all.
Even the LEDs went off. When I put the spaeaker with the front down on the floor, and connected it one more time, it made a few more thuds and flashes w the LEDs, but that was it.
I removed the back part with all the electronic stuff in it, and had a look, but i am a total user, not a tech expert, so I couldnt find something I could fix. I hoped for a fuse, but it doesn't seem to have any.
Hope somebody can help me.
SOURCE: Dishwasher not draining
Hi James:
What a coincidence. I am having same issue in my GE washer and I called a handyman. He came, checked through to make sure there is no blockages and concluded it is the pump. He said it is going to cost 350-400 and recommended I buy a new one instead.
Rav
Posted on Jan 26, 2008
Drummernick
  • 440 Answers
SOURCE: Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Posted on Feb 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: power up problem
i will need the model number of your set in order to help you with your problem. Please post the model number and I will try to help you out with the problem.
Posted on May 07, 2008
  • 36 Answers
SOURCE: My PC speakers not working
hi , please follow this
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bph07154&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on May 23, 2008
VinayT
  • 1884 Answers
SOURCE: Toshiba 50HP16 Plasma tv has
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Posted on Oct 07, 2009
Where do you add clutch fluid on a 97 Saab 900 SE?
there is a small tank to put fluid in should be on the firewall if the pedal went to the floor the line broke or the slave cylinder for the clutch went bad
Oct 17, 2017 | Saab Cars & Trucks
Truth b2030a studio monitor has power, but no sound?
Did you buy the second hand and with which gear do youvconnect them
Jul 22, 2014 | Behringer Truth B2030A Speaker
No sound from woofer behringer truth monitor b2031
first check woofer (end wire problem )
remove woofer from circuit
test with 1.5v battery cell touch parallel woofer lead neck
if disturbance sound come from woofer
woofer is ok
Apr 29, 2014 | Behringer Truth B2031 Other Dj Equipment
4 wheel drive stopped working
My 95, years back went out under warranty. Had it replaced by the dealer and it went out again the next winter. It was replaced again under warranty. I was told by the service manager that the actuator needs to be install a certain way or they will fail again. You might try checking with a Chevy dealer or on a forum for more answers.
Jun 13, 2017 | 1995 Chevrolet K1500
Why did my Behringer b212d horn stop working.
The problem is bad high freq. IC TDA7293.
There is no pasive crossover.
Nov 30, 2012 | Behringer B212D Powered Speaker (550...
Behringer Truth B2031A powered monitor speaker - radio interference in left speaker
A well know problem to the Behringer Truth B2031A speakers is radio interference and noise. I had the same problem with mine and found a solution on a forum!
If you open the speakers, you'll see a cable from the main board that runs to the 2 lights at the front (on/limit LED's). It functions as an antenna... Disconnect it and your speakers are silent, finally. (OK no leds, but I can live with that).
Oct 24, 2010 | Audio Players & Recorders
Sounds like flat tire but not
Have your universal joints and CV joints checked. I had the same problem and the Jeep dealer had it on the lift 4 times before they found it.
Mar 11, 2010 | 1998 Jeep Cherokee
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
Nov 08, 2009 | Behringer Eurolive B212A Speaker
Lcd speakers
I suggest to unplug surround and sub woofer so you will get sound from front speakers only.
Dec 12, 2008 | LG 42LG50 42 in. LCD HDTV
182 people viewed this question
 Grubhead
Grubhead
