Question about Nokia N79 Cellular Phone
When get started, shotdown and then started and shutdown
Hello, I just brought a N79, when starting with charging processs complete signal appeared 3 minutes after. Then when trying to start the phone, it entried to the main page and shut down in few seconds, (this was done without SIM), then returned to the main page and go to stand by again....this accurs 3 or 4 times and then it shutted down....with SIM incorporated, the phone ask for PIN and after few seconds went to stand by BUT NEVER GETS TO THE MAIN PAGE......you think that flashing the device and updating the software will solve the problem??.....THANKS
Sebastian
Why doesnt nokia N79 start
Your SIM card is probably locked. Contact Windows for more information
Feb 02, 2014 | Sony Ericsson Cell Phones
I want to format my mobile
  • On some forums it is reported that you can make your NOkia 97 work smoothly (after a crash) without formatting it;
  • Turn off your phone
  • Connect the charger
  • Remove the charger when the screen lights up and wait until it goes off.
  • Turn on the phone immediately after using the Power button on top.
  • After the vibration at start up, plug-in the charger.
For formating follow these Just follow the steps
Make a backup of contacts in your another sim.
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
Jan 17, 2011 | Nokia N79 Cellular Phone
I entered the wrong passcode, now its disabled, it says connect to itunes when i do it says restore, i say yes, it goes thru a process but says unable to restore error code 1611 - please help!!!
1. charge the iPod battery to max
2. Ensure you have latest iTunes
3. Shutdown your PC; complete shutdown
4. Unplug ipod USB
5. Start your PC
6. Fire up iTunes
7. Connect the iPod to an USB
8. Start the restore
Jan 02, 2011 | Audio Players & Recorders
Shotdown
Hello Sir\Ma,
Your question or problem is not stated clearly. Kindly clarify the problem so as to provide the best solution that befit your problem. Is it a shutdown problem you have or your phone will just go off unnecessarily. Please, state the phone brand and model as well.
Regards
Sep 14, 2010 | Lands Phones
Start up on acer aspire 5534
you will have to run it in safe mode 1st and run a virus scan, let me know if anymore problems and i will see if i can help.cheers
Dec 12, 2009 | Acer Aspire 5720 Notebook
ACer Aspire 5100 Sudden Completly Shotdown by itself
Try using canned air and blow the dust out of the fan and all the vents.
Nov 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
No signal prob...
some issue have to make sure
1) check battery charging indicate light on(yellow)
2) check AC adapter and DC jack connection if no bettery charging
3) check power on from battery or AC adapter that situation is same or not
4) take away HD DVD and change memory
5) plug extenal monitor
if no any thing show on the screen, you have to send to repair by the specialist.
Sep 27, 2008 | Acer Aspire 3100-1405 Notebook
AUTOMATIC SHOTDOWN
my computer is automatic shotdown in 15 min...what is the problem of my pc? all connection are connected and i'll checked the cards.and the settins are correct..what is the solution?
Jan 14, 2008 | Sharp VT-G21 21 in. TV/VCR Combo
Nokia N79 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
