ProScan and DVD Video Player
I have a Proscan model PS 2015 I tried to install a (New) Toshiba DVD Video Player Model SD-400 and I get nothing. I tried it on a Panasonic TV and it worked. I do not have the manual for the ProScan so I can not find any information about installing the DVD. I also have been looking for a manual for the ProScan, but could not find any. If you know where I can get a Manual for the ProScan please let me know.
Thanks
BP Gerber
  • PhilipG Jan 03, 2008
    What kind of answer is " contact the seller or call to the manufacturer "
    Thanks a lot for that answer!!!
    WHAT A waste of money and time.
    B Philip Gerber
  • Anonymous Mar 13, 2014
    PROSCAN tv with built in dvd player..plays for awhile then freezes & scratches dvd
  • 2,427 Answers
OK here is what to do
1.) from the dvd player there are 3 connections that we need
a.) THE YELLOW - video connection
b.) the RED - audio
c.) the WHITE AUDIO
2.) connect these to INPUT 1 on your television set
3.) SET YOUR TV TO INPUT 1
if you get no DISPLAY
4.) IN SETUP ON YOUR TV SET, Configure your tv to TAKE THE CONNECTION FROM RCA CABLES NOT COMPOSITE OR S-VIDEO
you can obtain your manual from the manufacture web page or you can google it with your BRAND MODEL and USER MANUAL or SERVICE MANUAL
If the above RCA connection dont work TRY S-VIDEO instead
Posted on Jan 03, 2008
  • 456 Answers
I think you have to contact the seller or call to the manufacturer or the last way is to find it in internet
Posted on Dec 18, 2007
What are the codes for a RCA universal remote for a Proscan 32 inch LCD TV with DVD player combo ?model number three to lb30 QD?
Two possible codes are 000 and 181. If neither works, use code search on your RCA remote to find something that does work and controls some or all functions of your Proscan unit. If a search through all codes stored in the remote fails, you may gave to try a different universal remote. All universal remotes do not store all possible codes.
Apr 26, 2017 | RCA Televison & Video
Dvd player toshiba sd-350esb schematics would be great
Toshiba SD-350ESB Manuals
www.manualslib.com > Brands > Toshiba Manuals > DVD Player
... User Manuals. View online or download Toshiba SD-350ESB Owner's Manual. ... Manuals and User Guides for Toshiba SD-350ESB. ... DVD VIDEO PLAYER.
Toshiba SD350ESB DVD player - Instructions Manuals
www.instructionsmanuals.com/modelo-8363-en-DVD+player.htm
Download instructions for TOSHIBA SD350ESB. Toshiba SD350ESB DVD PLAYER. Click on the instructions manual you would like to download for the model ...
Nov 07, 2015 | Toshiba Televison & Video
I want to watch netflix on my proscan tv, but I've put the tv on every channel and netflix doesn't pop up
it could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
Nov 29, 2013 | Proscan Televison & Video
I own the proscan the 37' LCD TV with DVD. Model #37LB30QD Recently the dvd player would play dvd's and stick. Now it does not play anything put in, and the only sound that can be heard is a...
It is possible that your set might have been hit by asmall power surge and if you leave your set unpluged fromthe wall for 40 Min., it will reset back to normal.
Jul 05, 2011 | Proscan 32LB30QD 32 in. LCD TV
Our new Toshiba SDV398KC2 will not play a DVD. It is like it is on the wrong channel. It shows the DVD playing with the counter but does not show it on the TV. Can you help?
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Nov 18, 2010 | Toshiba SD-3980 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
I have a proscan tv model #PS27108, I do not know how to hook up the dvd player in regards to the cords and what channel to put it on? I would appreciate any help with this! Thanks in advance?
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in.
90 selects S-video and audio 1 in
91 selects composite and audio 1 in
92 selects composite in 2 and audio 2 in
Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD.
If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4.
tom
Oct 22, 2009 | Proscan PS27108 TV
Televison & Video Logo
562 people viewed this question
Top Televison & Video Experts
