Question about Microsoft Xbox 360 Console
No visual on tv through 360
When i turn ob the 360 it loads up the game but i can not see anything, i thought that it might be the av cable, however i have since tried 2 other av cables and i am still getting the same problem.
  • 85 Answers
Do you have sound? and what are the cables set on HDTV or TV? If its set to HDTV and you dont have an HDTV then the picture will just be snowy and you will hear the sound of that game, just no picture. If this isnt it then it is your scaler chip which is an issue that MS needs to take care of or if you have a replacement plan you can use that as well.
Posted on Dec 17, 2007
  • Anthony Dec 19, 2007
    Your ana scaler chip has gone bad you will need to replace your Xbox 360 using a replacement plan or contact MS directly.
How do I connect my xbox using a hdmi cable
Step 1 Plug hdmi cabel into back of Xbox and TV
Step 2 Turn on your Xbox
Step 3 Go to your settings
step 4 Go to video or visual
step 5 Look for anything like output or somthing like that
step 6 Change output to hdmi
step 7 It should test the connection so change the input on your TV from av or whatever you were using to hdmi
Step 8 Rate this solution and enjoy hd
Any problems question or concers just let me know
Oct 16, 2010 | Microsoft Xbox 360 Console
No screen but sound works perefectly
There might be a problem with the AV cables (Audio Visual) or theres more then 1 port for the AV cables to go. If there's more then one AV station on the TV try switching to the other ones.
Feb 18, 2010 | Microsoft Xbox 360 Console
We turn the tv and xbox on but there is no picture. We can hear the xbox power up and the tv works otherwise, but no visual for games.
is there sound? check the connections in the back of the tv. if you get red lights on the xbox, then it means a cable is loose some where. check the av swith on the av cord connected to the 360.
Sep 29, 2009 | Microsoft Xbox 360 Console
My Xbox360 has no video. It dosnt show anything on the TV or it's not loading movies or games.
make sure your av cables (or HDMI) are plugged in. if they are it might be time for new cables
Jul 21, 2009 | Microsoft Xbox 360 Console
Assassin's Creed - loaded played, turned tv off can't see xbox
that is nothing to do with the update iv done one for nearly every other game.
try to manually find the xbox through your tv i have to find it myself all the time. it looks like the auto find on your tv has changed, but it shouldnt be anything to do with the xbox.
May 16, 2009 | Ubi Soft Entertainment Assassin's Creed...
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
No picture from my xbox 360 to my tv??
It is the solder under the GPU chip. Same as the 3 red light problem. YOu can send it to us if you want it fixed.
Jan 03, 2009 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Red Lights
Hello misspay,
According to Microsoft Support, the 4 red lights mean the Audio-Visual (AV) cable is not connected or plugged into your Xbox 360 correctly. Please make sure the AV cable is connected correctly to your Xbox 360. To do this, disconnect the AV cable and firmly connect the AV cable to the Xbox 360 console.
I hope this fixes your problem here is a link that will provide you with more solutions to try and fix the issue.
Agent Xiong
May 22, 2008 | Microsoft Xbox 360 Console
Playing psp game in tv using component av cable
i have connect the psp av cable but i can't play psp games plzz guys help!!!!!!!!!!!!!!!!!!!!!!
Apr 18, 2008 | Sony ACY-BR81/OB
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
