Question about Sony NWZ-E436F MP3 Player
My player ran out of charge(message:"low battery please charge"), so i connected it to my pc via usb cable.it then said "connecting" and while it was on that, i could see the battery sign on the bottom right get charged, but then the screen said "Connected USB (MTP)" and the battery icon showed a full charged battery. The problem is that its not fully charged because when i switch it on the message "low battery please charge" reappears.... please help me as soon as possible thanks
  • 63 Answers
Your device is corrupted and you need to reformat it.
Posted on Sep 27, 2009
Testimonial: "Thanks, but please tel me how i can format it when i cant even start it up coz the battery is too low... thanks again"
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
Jan 24, 2013 | Apple iPod classic MP3 Player
My nextar will not turn on and it is straight out of the packaging. When the usb is plugged in, the two default songs are listed, and they are able to be played. Please help me with this issue, as I...
I think you have a new device and you wanted to use it at first and the battery wasn't charged.
The player has a built-in lithium-icon rechargeable battery. It is charged via USB connection. You
are required to charge it when you use it for the first time. It takes about 3 hours to fully charge the
battery. Connect the larger end of the USB cable to the USB interface of PC, and connect the
other smaller end of the USB cable to the USB interface of this player. The device is connected to
PC and being charged.
For maximum performance, lithium-ion batteries need to be used often. If you don't use
the device often, be sure to recharge the battery at least once per month.
I hope your item will work fine after the battery is charged.
Thanks.
gylacz
May 03, 2011 | Nextar MA797 MP3 Player
Hae bought 2gb Veg MP4 players. Can add music files to players when connectd to computer. But have tried to charge on numerous computers and they won't charge. Anybdy got any ideas or know how to fix? ...
Try to charge it via a battery charger. Change a USB cable to connect PC to make sure the USB cable is good. And change PC to charge the mp4 player. Compare the results, you will know where the problem is.
Jan 09, 2010 | Umax Vega108 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
My Creative Zen keeps giving me the message ''shutting down'' but just stays on, even after the reset feature is used. Any ideas how to solve ?
Sometimes manufacturers release firmware updates to fix issues in the units. I would suggest attempting a firmware update if your firmware is not the latest version. (The Creative website lists the current firmware revisions in their support area for their players.)
If you are able to connect to the PC via the USB cable, I would try the Creative MP3 Player Recovery Tool available through their support tab as soon as the unit has at least 50% charge.
If the Zen player is completely locked and will not connect to the PC, you may have to let the battery go low and allow the unit to turn off by running out of power. Then plug the player into the PC to perform the initial slow charge and after some time (15min), the player will attempt to turn on the screen when it has enough charge. When it turns on, you should be able to tell if the PC connects to the Zen as well. If it connects, continue to allow the Zen to charge until you have at least 50% charge and then attempt the Creative MP3 Player Recovery Tool.
If the Zen doesn't connect to the PC, there is a deeper problem.
Sep 01, 2009 | Audio Players & Recorders
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Sony NWZ-E436F MP3 Player Logo
241 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
