Question about Xerox Office Equipment & Supplies
Xerox workcentre 238 fault code 07.515.00 - Xerox Office Equipment & Supplies
5 Suggested Answers
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
checkitright
  • 1362 Answers
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Posted on Sep 08, 2008
goodgold
  • 389 Answers
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Posted on Sep 13, 2009
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
What is the fault code 124-373 of xerox workcentre 5230
power down machine,
remove drum,
power on machine,
reseat drum
Apr 08, 2013 | Xerox Workcentre 5225 / Copier, With...
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Mar 12, 2012 | Xerox WorkCentre M128 Copier
My Machine Xerox Workcentre 7328 getting a fault code 062-393
Fault Code 062-393: Scanner Control Board Failure. Power off. wait 1 minute. power on. if still broke call for service - 1-800-821-2797.
Oct 20, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Aug 06, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Fault code 006-381 on a xerox workecentre 24
That is a ROS ( laser ) fault.Either the ROS unit or the MCU ( main processor board) have failed.
Honestly, its a tossup as to which is the problem.
Mar 30, 2010 | Xerox WorkCentre M-24 Color Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
177 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
