Question about GE Dryers
Model #DJXR433EC2WW Ser.# MG753742A Will not turn on. Has Power.
Have a GE electric dryer model DJXR433EC2WW. Whenever I select the dryer mode/time option, the dryer turns on by itself without turning the start switch (door closed). The dryer only stops when it...
I have seen that in those dryers before and it has always been the motor that is causing it to start without engaging the start switch.
GENE
Sep 16, 2011 | GE Dryers
RCA md#DS52W20/ser#E194C10kp power light blinks
You need a component tech like me for this job.
Since I can't advise you poke into that dangerous thing.
Call a guy
Please rate this answer
Aug 06, 2011 | RCA HD52W59 HDTV Projection Television
Toshiba l20-217 model-2xe 01p00uen ser no.
To repair missing NTLDR orcorrupted system file/s, boot up with the Windows installation CD then - Press R to repair wheninstructed. Press 1 or Enter to repairthe C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process willtake quite a long time.
Jun 03, 2011 | Amstron Toshiba Satellite L20-217 Laptop...
Djxr433ec2ww... It seems my dryer's motor mounting plate is lifting on the right rear corner when tension is applied causing the blower wheel to be off center and scrape the side of its housing. There is...
drill a whole further down the tension plate add a few more screws to the base and increase the tension on the belt spring
merry christmas
Dec 22, 2010 | GE Dryers
Hobart electric convection oven model #cn90 ser. # 07-007-968-nj
Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
Apr 09, 2010 | Hobart HEC501-240V Electric Oven
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Tv\DVD Wont turn on
Quizas el sistema de la vcr este fuera de tiempo,por causa de la banda del motor de carga el aparato tiene que ser abierto para ser reparado llevalo a un taller.
Mar 28, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Washer will fill and run but will not drain or spin.whirlpool estate stock# taws690a mod.# taws690ano ser.#cc4621151
Could be a bad motor, or something stuck in between the tubs, like a nail, wash cloth, sock.
Try to turn the belt both ways with no power on, unplug the machine, before you start. Take the Belt off, then turn the motor pulley , then turn the transmission both ways. All should turn freely.
On this model i believe you can just tilt the machine back to do all this.
Mar 15, 2008 | Washing Machines
Dryers Logo
153 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
