Question about Canon PowerShot A95 Digital Camera
When I take a picture the results look like a striated picture, leaving stripes in the display and then in the picture.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Sep 26, 2009
Using an Epson stylus DX6050 I am trying to print photos from my computer files. The print I get is striated in bands of about 1cm. How can I get an acceptable print? Printing directly from the scanner or...
Try updating the driver here. It should be the communication between your computer and printer that's causing these pictures to print erroneously.
Hope this helps!
Fix14
Jun 16, 2010 | Office Equipment & Supplies
Switch on. Picture OK for 3-4 seconds then vertical stripes only
IT NEEDS SERVICING, THROUGH THE CERTAIN HEAT ON THE VERTICAL IC, THERE HAS BEEN DRY JOINTS ..RESOLDER IT, FOR BEST RESULTS TRY TO RESOLDER THE OTHER HEATED PARTS..IT WILL WORK
Oct 13, 2009 | Televison & Video
When I take a picture the results look like a striated picture, leaving stripes in the display of the picture.
Right, camera has bad CCD Imager problem and that part will be replaced.
canon will repair A95 Free of Cost for CCD Imager problem.
Please click Canon CCD Imager Advisory for details.
Good luck.
Mar 07, 2009 | Canon PowerShot A95 Digital Camera
Striped color distortions on Nokia 300 Xa flat panel
This is power supply problem.
1. First u replaced the power out put capacitors , 6V, 12V, etc.
2. cheak the diodes.
Oct 17, 2008 | Computers & Internet
Stripes on my pictures
Recent purchase - Return to seller as faulty product
Jun 03, 2008 | Kodak EasyShare DX7630 Digital Camera
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Apr 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
Pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Canon PowerShot A95 Digital Camera Logo
127 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
