Question about Dell Computers & Internet
Power light on monitor blinks green, monitor is dark
  • ginger633 Sep 26, 2009
    The answers were not relevant. The greenlight on the monitor of my Dell computer blinks green and the screen is dark.
  • Dell Master
  • 497 Answers
Perform a Monitor self-test to determine whether the issue is with the Monitor or with the Video card of the Computer/with the Computer.
1. Turn OFF the Monitor.
2. Disconnect the video cables that connect the Monitor to the Computer.
3. Turn ON the Monitor.
4. Before the Monitor enters power saving mode, on the front of the Monitor, press and hold the right arrow button for five seconds. (if applicable)
NOTE: If the Power indicator light becomes solid orange, the monitor has entered power saving mode. If this happens, repeat the self-test procedure from the beginning.
5. The Power indicator light will turn on and green, and a CABLE DISCONNECTED or NO SIGNAL box will appear with four color bars (red, green, blue and white). This indicates the LCD is functioning properly.
6. If the LCD is functioning properly, turn off the Monitor, reconnect the video cable that connects the monitor to the Computer, then turn on and use the Monitor as normal.
NOTES:
  • The CABLE DISCONNECTED box may disappear after a few moments, and the Power indicator light may turn red. The self-test can be repeated by pressing the POWER button.
  • If the CABLE DISCONNECTED box does not appear while the Power indicator light is green, or if the Power indicator light does not turn on, service for the monitor will be required.
Good Luck!!!!!!!!!!!
Posted on Sep 26, 2009
  • 324 Answers
Please check the SMPS its working or not and please check the power cord was inserted correctly or not
Posted on Sep 25, 2009
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
Feb 24, 2010 | Hannstar I-Inc TW-191D Monitor
Monitor is blinking green light but no dark screen
does you cpu have a built in vga or you use a separate card? check at the back of the cpu, if you are using a cpu that has a built in vga and youre using a separate vga card may you have just connected your lcd monitor on the built in in which many cases will not work you need to connect your lcd on the separate vga card, if that is not the case and you head a beeping sound with intervals then there a problem with your vga card now if you use built in video you need to put on a separate vga card agp or pci-e which ever is supported by your motherboard, hope this help
regards
michael
Nov 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Apr 20, 2009 | Samsung SyncMaster 720N Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Computers & Internet Logo
139 people viewed this question
Alun Cox
