Question about Toshiba TEC B-452 Thermal Label Printer
Thw sensor isn't working - Toshiba TEC B-452 Thermal Label Printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Check that it is correctly selected or change the sensors
Posted on Jan 14, 2014
Radiator fan is not working
check temp sensors for operation probably 2 as they switch the fans on at a set temp. Check that the fan is free to spin and not seized or use jumper leads and apply power directly to thw wires to the fan to eliminate a burnt out motor
Jan 13, 2013 | 2005 Chevrolet Silverado
What happens when a knock sensor isnt working ?
If the knock sensor isn't working it isn't a real problem IF the engine isn't knocking. The sensor detects the faint pinging that comes before engine knock and sends a signal to the ECM which then begins to ****** timing until no pinging is reported by the sensor. If you do have knock and the sensor isn't working you can severely damage your engine.
Oct 14, 2012 | 1997 Infiniti.5 J30
The printer keeps saying there is a paper jam and there isn't one
All you do is take out all the paper and put it back in. if that doesnt work try unplugging the printer and plugging it back in/turning it off then turning it back on. if all else fails try just totally restarting thw whole thing. Good luck! :)
Oct 08, 2012 | Kodak ESP C310 All-in-One - Multifunction ...
Transmission will not shift into reverse
Sounds like the shop didn't do their job right. Call them and take it back if you paid to have it rebuilt. It should not be your problem to solve it. Work should be guaranteed, and if it isn't, you should take matter up in civil court.
Aug 29, 2012 | 1993 Dodge Dakota
Lexmark wheelwriter 3500 indicates code 215.
215 is print wheel error. Remove the printwheel look for dirt and debris in that area, if you have a compressed air source blow thw P/W area out. If these don't work the printwheel sensor is likely bad.
DickyO
Jun 17, 2011 | Lexmark Wheelwriter 3500 Typewriter
Where do i find the Mass Air flow sensor under the hood of my 2003 kia rio?
Thw Mass Airflow Sensor is located between air cleaner assembly and the throttle body. Thanks.Helpmech.
Nov 14, 2010 | 2003 Kia Rio
WILL THW MAF SENSOR STOP A CAR FROM RUNNING
Hi, If you have a faulty MAF sensor, It could cause some hectic drivability issues, usually setting a check engine light. your vehicle should still run , even if the sensor is unplugged. If you can not get it running, I would start at basics, air, fuel, spark. Thanks..
Sep 22, 2010 | 1996 GMC Yukon
Check engine light obd II code P2A00. Where is the oxy sensor located.
there are two sensors one before the catalyst and one after,follow thw exhaust system from the side of the head and the first sensor you meet is sensor one which relate's to your fault
Apr 16, 2010 | 2007 Dodge Ram Truck
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
Toshiba TEC B-452 Thermal Label Printer Logo
71 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
