Question about Konica Minolta magicolor 2430 DL Laser Printer
2430DL WHEN I PRINT A LARGE COLOR PICTURE THE PICTURE HAS A LIGHT STREAK FROM TOP TO BOTTOM. ACTUALLY 3 OR 4 STREAKS ALL WITHIN AND INCH OF EACH OTHER.
  • 1 more comment
  • Anonymous Jan 12, 2008
    me too
  • dimbulbz Feb 27, 2008
    I too have the problem with pictures showing lines running through them. I dont know how to remove the drum and clean the lens - I'll try to fiure out what that means and clear it. If you know please respond, I have limited time to fix this.
  • Guest15068 Apr 13, 2008
    When I print there is 1 solid line from top to bottom on left side of the paper about a 1/4" wide.
Yes!!! This certainly worked for me!!! Thank you!!!
Cleaning the lens with a dry cotton (Brook Brothers) hankershift did the trick!!!
Posted on Apr 18, 2008
You probably have dust or toner particles on the laser lens. Take out the drum unit and wipe the laser lens with a clean soft cloth.
Posted on Jan 12, 2008
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
My Olympus P400 Printer comes out with streak on the left side
If a hard reset of printer electronics does not restore proper operation there may be an inherent defect in the unit causing this.
Sep 05, 2017 | Office Equipment & Supplies
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Jun 03, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
285 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
