Question about Roper RAX4232KQ Top Load Washer
What year is Roper washer model RAX423KQ0? - Roper RAX4232KQ Top Load Washer
  • 612 Answers
I can't find the year made but I can tell you that it's made by Whirlpool and it's one of the most reliable units made. The only problems you might have is
  1. Coupler
  2. Water Pump
  3. Lid Switch
These are the most common parts for these machines. Each are less than $35.00. I'n my opinion the #1 washing machines made. As far as the year, you will most likely have to call Whirlpool.
Posted on Sep 25, 2009
Sm8280871 is the model listed under the lid. It is a Roper by Whirlpool top load washer about 10 years old. I can hear the motor however the washer does not spin, or drain. It appears that it tries to...
I suspect the V belt is worn out try taking the side cover off you would have to tilt the machine another helper maybe needed make sure you drain the remaining water out and unplugged the cord safety first
Oct 24, 2013 | Roper RAK2751WWH Top Load Washer
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I am thinking of buying a used Roper washer and dryer, model # RAX4232JQO and YREX4634JQO, respectively. Anybody know the year of the make? Are they good appliances? Thanks
Roper is manufactured by Whirlpool and uses Whirlpool parts. This is a fairly reliable washer and (from an appliance repairman's perspective) one of the easiest washers to troubleshoot and repair (if required). Nearly all the parts are inexpensive as well. The gearcase (transmission) is the most expensive part in the unit (about $150) and even it is simple to replace by the average do-it-yourselfer.
The dryer, if maintained properly, is also very reliable and an ease to work on. The heating circuits are the most common fail items and average about $100 to replace (all parts combined). This is also a simple appliance to work on from a repairman's point of view.
Make sure it is installed correctly, by using semi-rigid exhaust vent ducting. The following link can give you some helpful advice on how to maintain your dryer to prevent premature failure of components:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of any dryer heat related problems is caused by poorly installed, excessively long, kinked, or clogged exhaust vent ducting. I can't express that enough. Failure to maintain a dryer by cleaning it periodically can also create a fire hazard.
The age of the appliance is determined by the SERIAL NUMBER. The following link explains how to determine the YEAR and WEEK of manufacture:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
If the units are in fairly decent shape, I would seriously consider purchasing them. Even the older Whirlpool manufactured washer and dryers still use the the same parts as the newer models today. So, age isn't necessarily a factor.
If you have any questions, or need future advice (if you experience any problems), please let me know. I hope this helps you.
Dec 19, 2009 | Roper RAS6233KQ Top Load Washer
I have a roper washer that wont spin. Probably the coupler. I have changed couplers many times on other types of washers whirlpool amana and kenmore. etc. is the process the same with a roper ?
exact same as a whirlpool, for they own roper, amanas do not have couplers..... the kenmore might if the model starts with 110.********* or 118.*********
Jan 16, 2009 | Roper RAX4232KQ Top Load Washer
Roper Washer RTW4300SQ
if the drive coupling is ok then the transmission is the problem verify for sure that the coupling is good
Apr 18, 2008 | Roper RAS8244KQ Top Load Washer
Mo del RAB 1121EW1 serial number CG 402 1770
This is a direct drive washer so there is no belt. The drive coupler that connects the motor to the tub may need to be replaced.
Mar 05, 2008 | Roper RAB2121KW Top Load Washer
UNBALANCED WASHER
Does it happen all the time, with no connection to laundry quantity? In case of a positive answer, it sound like a shock absorber issue. Could be that it's moved from its place or become malfunction and should be replaced. Good luck
Aug 07, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
144 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
