Question about Dell Inspiron 6000 Notebook
How much would It cost me to get the motherload on my laptop replaced.
    Novelist:
  • 137 Answers
Would be more costlier than a new computer. because you might need a motherbaord and a technician who can come and install that for you.
so, dont waste your money in getting the motherbaord replaced. get a new computer. that would be the smartest thing to do.
Posted on Sep 26, 2009
  • 3,940 Answers
I6000 motherboards run about $150 on Ebay and labor is usually about $100 to $150 to have it installed.
Posted on Sep 25, 2009
Battery charge does not last long
If your laptop battery is more than 3 years old, it sounds like it needs replacing. Search online for your laptop model number to find a replacement battery for a low cost. IF cost isn't an issue, then write the model number down and go to an electronics/computer store for a replacement.
Aug 30, 2015 | Computers & Internet
Dell Inspiron n5110 home premium laptop
Google "replacement screens". You'll have a lot of choices. Find the one for your laptop to see what it costs. Replacing it is tricky but not impossible even for a rooky.
Jan 24, 2014 | Computers & Internet
My toshiba laptob Model # A205 S4577 freezee in between 20minutes i have shown to my friend he said the has to be replaced and even some part is burning at a point where you place your charger in your...
That part costs just $5. The labor to install it will cost about $200. But if the plastic of the board on which the charger port is fitted has been damaged by the burning circuit then it can't be replaced or repaired - the laptop is indeed dead. The laptop will have to be opened to see if that is the case - that will cost you $50 at a pc repair shop.
Aug 05, 2011 | Toshiba A205-S4577 Notebook
My hi grade laptop screen is not coming on
Try connecting this to an external monitor, see if it gives an image,if it does, you will need to check the inverter and back light of the laptop screen.
if it is the backlight at fault, you should see a faint image on the screen in a darkened room
If it is the inverter, the screen will remain black with no image.
Top replace the backlight, the screen itself must be replaced ( approx. cost £60.00 used)
Replacing the inverter approx cost £10.00.
neither are difficult jobs, but the cost may outweigh the value of the laptop if it is the backlight.
Knowing Hi-Grades though, the above points are academic. I'd be 90% certain that the graphics chip has failed ( no picture seen on external monitor). this is very common with hi-grade laptops, as the cooling to the graphics chip is very poor. Sadly in this case, you will need to replace the motherboard, the cost of which will certainly not be worth it
Jul 18, 2011 | Computers & Internet
How Can I reset the SMC 8612XL3 switch to default factory mode?
hi there Ramesh -- please rate me
i believe i have what you asked for .. read on
i found the following information
a 2 page overview for this item
http://www.smc.com/files/AR/ds_8612XL3.pdf
home page for this item
http://www.smc.com/index.cfm?event=viewProduct&cid=8&scid=44&localeCode=EN%5FUSA&pid=1179
**MOTHERLOAD**
manual http://www.smc.com/files/AQ/MN_8612XL3_MAN.pdf
command.
Default Setting
None
Command Mode
Privileged Exec
Command Usage
This command resets the entire system.
Example
This example shows how to reset the switch:
Console#reload
System will be restarted, continue ? y
i hope this helps you
Nov 05, 2010 | SMC 8612XL3 101001000Mbps TigerSwitch 1000...
My laptop hs a black screen problem, the laptop will turn on, but the screen will continue to stay black. i do not have money to get a new computer. i only used the laptop for a year, warranty is no...
There are a few reasons for this happening below are the reasons and how to fix them:
1. Your screen has died or
FIX- Replace the screen
2. Your backlight in the actual LCD panel has died
3. The LCD inverter has died
FIX- replace the inverter board
4. The graphics card in the laptop has died
FIX. See if the laptop will work using an external monitor (if so remove faulty screen and use as a desktop replacement).
FIX. Buy or aquire another motherboard for your laptop and change them over.
All of these problems are fixable and you can do your self with a bit of "Google" knowledge.
f you do not feel comfortable in doing it yourself then you can take it to a computer repair shop and they will diagnose and fix for you at an extremely inflated price.
N.B. A computer store near me charges $69 for a diagnostic test to tell you what is wrong and then it's $69 per hour after that, as an example they estimate a screen changeover will cost:
$69 for diagnostic test + (Parts cost) + 2Hrs Labour @ $69 p/hr
Total $207 (not including cost of parts)
LCD panels range in cost from a few dollars to some times the cost of a completely new laptop.
Nov 05, 2010 | HP Pavilion dv6000z Notebook
Clean machine still on even after cleaning with cleaning tablet
Patti - I had the same problem yesterday with my E8. If you still have an issue, and have cleaned the tamper area like tech support will tell you to do, try this...Turn off the machine and remove the tray. Use your fingers to probe around the metal thing in the middle. You will find several areas where grounds accumulate. I found two areas in particular - one on each side of the center - where I had the motherload of old grounds. Remove all this, then clean out the chute where powder goes. Replace the tray, turn the unit back on and run a cleaning with no tablet. When it asks for the tablet, open the top door, wait a second, close the door and continue. If you got all the gunk out, you should complete the cleaning cycle with no issues. But seriously, you have to use your fingers for the clean out. You can't see, and q-tips don't work..so you have to feel around. Good luck and let me know how it goes.
Jun 20, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
I would like a couple of cheats on ratchet gladiator on ps2
Well, if you wold like cheats...I have the motherload for you. These are just a few of the websites i go to for cheatcodes.
1. www.cheatcc.com
2. www.cheatsguru.com
3. www.cheatcodes.com
4. www.supercheats.com
I mean, these are all good websites, and I checked they all have Rachet and Clank cheats. but there are a lot more out there, and you may like others. I though, personally recommend cheatcodes.com, because they have awesome cheats and is a pretty good website.
Hope that helped, Good Luck!!!!!
Jun 12, 2009 | Sony Video Game Consoles & Games
Driver Motherload NEEDE
Click here for all the drivers for your mobo.
Enjoy,
Lee
Jun 12, 2008 | Intel Motherboard
Dell Inspiron 6000 Notebook Logo
103 people viewed this question
Alun Cox
