Question about Maytag Neptune FAV6800AW Top Load Washer
HI PROBLEM IS I AM GETTING A CODE LR. I ALREADY REPLACED THE LOCK SWITCHES LF AND RIGHT, THIS DID NOT CORRECT THE PROBLEM .
  • 335 Answers
Why did you replace the Left and Right hand lid locks? Typical fail codes from the left hand lid lock would be OP,OD,FL I thru my right lid lock away you only need the left lid lock for the machine to function as designed.
Do you think you might have may have some drive system binding related to One-Way roller clutch bearing, Spinner Assembly, Transmission, Tub Bearing, etc issue?
The Service Manual for reference. Sears Parts Direct for reference.
For a start point I would try the Motor Control Board Output Test page 15 of the SM and see what your results are.
Posted on Sep 26, 2009
    President:
  • 1,776 Answers
The "LR" code indicates a problem in the motor control board. Most times when the code is generated there will either be a blown fuse or a burnt spot on the motor control board. It may mean that a new motor and control board will be necessary. I would contact a qualified appliance tech to take a look at it. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 25, 2009
Turn signals do not work, have replaced module, still do not work
Find a wiring diagram an get a DVOM - digital volt ohm meter an do some electrical testing . Videos on you tube on basic automotive electrical testing , how to read a wiring diagram . Then go http://bbbind.com/free_tsb.html free wiring diagrams . What component controls windows an door locks , I know what does , what to see what you think does . The speedometer not working is probably the step motor inside the instrument cluster . New instrument cluster ! Replace the turn signal switch.
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door. The driver door module (DDM) is the master control for the door lock system but the rear integration module (RIM) contains the program that determines when the lock functions are permitted.
The vehicle is equipped with power windows controlled by the door modules. The DDM receives a window switch request, over the SBI serial data, from either the passenger door module wired to the window switch pressed or from the driver door switch assembly. The DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation.
If the status information to permit window operation is correct, the DDM sends the command to the door module controlling the window to move the window as requested.
Windows Power and Ground
The windows are powered by discreet power and ground circuits. These circuits are in the same dedicated connector as the window motor drive circuits.
These systems are very complex and are able to set DTC'S in the controlling module .Your best bet is to take your vehicle to a qualified repair shop .
DTC B3142 LF Unlock Switch Circuit Low DTC B3147 Passenger Unlock Switch Circuit Low DTC B3152 LF Lock Switch Circuit Low DTC B3157 Passenger Lock Switch Circuit Low DTC B3172 RF Window Up Switch Circuit Low DTC B3177 RF Window Down Switch Circuit Low DTC B3182 LR Window Up Switch Circuit Low DTC B3187 LR Window Down Switch Circuit Low DTC B3192 RR Window Up Switch Circuit Low DTC B3197 RR Window Down Switch Circuit Low DTC B3377 LF Window Up Switch Circuit Low DTC B3382 LF Window Down Switch Circuit Low DTC B3387 RF Window Up Switch Circuit Low DTC B3392 RF Window Down Switch Circuit Low DTC B3397 LR Window Up Switch Circuit Low DTC B3452 LR Window Down Switch Circuit Low DTC B3457 RR Window Up Switch Circuit Low DTC B3462 RR Window Down Switch Circuit Low DTC B3467 LF Window Express Down Circuit Low DTC B3472 RF Window Express Down Circuit Low DTC B3527 Window Lockout Switch Circuit Low
DTC'S are intended to point the qualified technician in the correct diagnostic path. You may have a communication or network problem . Are you familiar with class two serial data bus communication network . The simple bus provides a means for information exchange among the vehicle door modules. Door module information on inputs and commanded outputs are converted to serial bus interface data for exchange among the door modules. The DDM can also take information from modules connected to the class 2 serial data circuit and relay the command to the simple bus interface. The vehicle power mode message (ignition switch position) from the DIM is an example. The DDM periodically addresses each module on the simple bus interface. When a module does not respond to the DDM, the DTC for that module is set. You can't just replace these modules , some need to be programmed . Dealer only ! First check codes , power an grounds etc....
Jun 29, 2016 | 2000 Buick LeSabre Custom
What does the master window switch control on a 2003 trailblazer
The master window switch will control LF window, LR window, RF window, and RR window. There is also the door lock switch on the module and a window lock switch.
I hope this is helpful.
-Scott
Feb 14, 2015 | 2003 Chevrolet TrailBlazer
My kenmore flat top stove front burner quit working. I replaced the 9" element and it still will not work. Any suggestions.
your burner switch is wattage rated ( as all burners are ) you want to check H1 and H2 for voltage 220vac and replace it with the correct switch Rf,Rr Lf Lr some shafts on controls are colour codded
refer to your model number and proper switch and element location
Cheers
Dec 11, 2013 | Kitchen Ranges
Wiring diagram for the door of a 95 ford explorer
Windows Up LF=Red/Yellow, RF=White/Yellow, LR=Gray/Orange, RR=Red/Black
Windows Down LF=Tan/Blue, RF=Tan/Blue, LR=Yellow/Blue, RR=Yellow/Black
Door Trigger Black/Light Blue Driver's Kick Panel
Door Lock Pink/Yellow (-) Driver's Kick Panel
Door Unlock Pink/Green (-) W/o Keyless Reverse Polarity
There are no GPS wires in the door of that vehicle.
Apr 13, 2011 | GPS
Hi I need the wiring diagram for the radio harness
Hello! Black=Ground...Blue=Antenna...Red=+12volts constant (memory)...Yellow=Switched +12volts...
Left front+White...LF- White/black...RF+Gray..RF- Gray/Black...LR+Green...LR-Green/Black...RR+Purple
RR-Purple/Black.............
Guru...........saailer
Feb 04, 2010 | Sony CDX-GT110 CD Player
Color code radio wireing 2001 malibu
Battery Orange +
Accessory Yellow + Note this vehicle does not have a dedicated accessory turn on wire . use a lead from the ignition switch or fuse panel to supply accessory voltage .
Ground black -
Illumination Gray +
Dimmer Brown +
Lf Speaker Tan +
Lf Speaker - gray
Rf Speaker + Light Green
Rf Speaker - Dark Green
Lr Speaker + Brown
LR Speaker - Yellow
rr speaker + Dark Blue
rr speaker - light blue
Aug 28, 2009 | Car Audio & Video
Need wire color codes for 2000 cavalier stock radio
Battery ORANGE (+) RADIO HARNESS
Accesory need to go to the ign switch cause radio does not provide a switch source.
Ground BLACK (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Feb 25, 2009 | Car Audio & Video
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Radio wiring color codes
u need the colors of the radio or the car wires.... here are the car wires and the radio are below that. I suggest however gettiing a wiring kit..They are around 8 dollars and well worth the money. It makes is so easy to connect a radio.
RADIO 12V|orange + at radio
RADIO GROUND Black
RADIO SWITCH yellow
POWER ANTENNA dk. green at radio LF SPEAKER tan - gray at radio or LF speaker
RF SPEAKER lt. grn - dk. grn at radio or RF speaker LR SPEAKER brown - yellow at radio or LR speaker
RR SPEAKER dk. blu - lt. blu at radio or RR speaker
Radio wiring
constant power yellow
switched power red
power antenna/amp turn on blue
illumination is orange
all speakers the one with the black stripe is the negative connection.
right rear is purple
left rear is green
left front is white
right front is grey
hope that helps ya...
Aug 30, 2008 | 1999 Oldsmobile Alero
ABS Light gives out three codes,Where can I get a list of codes to trouble shoot by?
Most Honda ABS warning light will blink in 2 parts, main system and then sub system to form the code pair. As an example is 3 blinks then 3 blinks is a code 3-5. Once determined, reference below listing.
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Honda Accord Cars & Trucks
Maytag Neptune FAV6800AW Top Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
