Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I'm trying to do some washing and I'm running the water but it won't fill up
  • Whirlpool Master
  • 1,606 Answers
Your drain hose is stuffed into the drain pipe too far , or taped to the drain pipe (possibly to try to stop the drain from backing up ) . Your sewer system is causing a syphon effect to the washer , causing drain as it fills . You can get a syphon break , which attaches to the drain hose , to stop this problem . Any appliance store or maybe even Home Depot , will have this part .
Posted on Sep 26, 2009
Washer will only fill slightly on rinse cycle and not at all on wash cycle
Is the water on? Does the pump run when emptying machine? If yes to both, try running the machine through a spin cycle if you can and let it finish on its own. The valve should close and allow it to fill. Also, top or front load washer? ... These may help How to Fix Washing Machine That Won Fill With Water DoItYourself com
Jul 17, 2018 | Washing Machines
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Washer won't fill water runs out bottom
either you have a bad drain hose or the drain pump has a bad seal behind the outer case
May 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine won't turn on
OK, you have a model with a mechanical timer. Try advancing the timer to the spin portion of the cycle and seeing if it will run there. If yes, problem is most likely with your water fill valve. If no, problem is most likely a timer issue.
Nov 18, 2011 | GE Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
51 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
