Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Badger 5 leaks from the bottom
I rread on another site that you can replace the seal if it is leaking from the bottom. Has anyone tried that?
    President:
  • 1,124 Answers
Yes - you can find the parts here and they come with instructions..
http://www.repairclinic.com/Appliance-Parts?s=t-badger+garbage-%3d%3dd601329
have a great day
Posted on Sep 25, 2009
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 desposaland it is leaking out the bottom by the cord,is there a seal I can buy,or can i even get to it,or just junk it and get another. Thanks Neal
Once the disposal is leaking there... it will cost more to repair then a new one will cost...
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 insink erator is leaking out of bottom. Is this a seal or something that can be replaced?
If it is actually leaking from the bottom there is nothing you can do except replace it, there are no user servicable parts in the bottom end on disposal. I would carefully check around drain outlet and gasket where it mounts on bottom of sink. If it's leaking around drain outlet from disposal there is a replaceable gasket there or on underside of sink where disposal mounts. If you find that it is leaking from either of these locations I would be happy to instruct you on how to change them Hope this helps you, Thanks.
Nov 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 plus and it started to leak water from the bottom of it. Please let me know if there's a seal I can buy and replace .
A new seal costs more then a new disposal..
heatman101
Sep 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking from bottom of disposal where
heatman101
t
Feb 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 leaks from bottom,which is cheaper repair or replace.
The seals are shot and it is probably a point at which it should be replaced since that particular brand doesn't have a great track record and is one typically installed in new homes for its low cost.
Feb 08, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water is coming out the bottom of my Badger 1 disposal. Solution???
Check the fittings, the hoses could be loose... If the leak isn't coming from there then you have a seal leaking or a rust through that is causing water to leak and would need to replace the disposal.
Oct 06, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 leaking from middle of unit when motor is
Make sure the seal is tight where the unit attaches to the sink. It may appear that the unit is leaking elsewhere but is not. If you are sure it is leaking at the case, check for cracks or you could have a bad pump seal internally, in which case the unit should be replaced.
Jul 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator leaking at bottom by electrical connection
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
May 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
If you need some part, take a look on amazon, here: Amazon com insinkerator badger 5 parts I bought replacement plate from there.
May 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
684 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
