Question about Homelite Garden
Homelite String Trimmer(ST155) Manual
I am looking for a Homelite ST-155 String Trimmer Owner's Manual. Can you please let me know where I can get one ?
#1 Taper
  • 1040 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
dsturbd
SOURCE: My Homelite ST 155 gas trimmer is hard to start
You have a leak on the carburetor. internal or external. the fuel we run now a days eats the gaskets up. gasket set is $8. +tax Easy to do if you pay attention to how it comes apart. The whole kit is a little more plus the little pump ball might be leaking too. Easy fix for most.
Posted on Jun 24, 2009
#1 Taper
  • 1040 Answers
SOURCE: Installing new line on my string grass trimmer
Jim
Posted on Jul 03, 2009
  • 3 Answers
SOURCE: Need parts for Ariens ST 622 string trimmer
MY ARIENS ST622 starts but then dies down quickly any ideas?
Posted on Aug 28, 2009
  • 474 Answers
SOURCE: carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Posted on Dec 25, 2009
I have a ST 155 Homelite String Trimmer: I put new primer button on, rebuilt the carburator.I can get it running,but no gas goes to the primer button. Carburator is a Zama ut no. 20539 , serial no.HI...
Sounds like maybe you got a gasket on backwards or crooked that is blocking the passage that the fuel pulls through... otherwise, perhaps the hose connection to the tank is not put back together right or may have a crack in it.
Aug 30, 2013 | Garden
I have a Homelite ST-155 String Trimmer. It says to prime the unit by pumping the bulb. I cannot find this bulb on the unit anywhere. Please tell me where it is. Thank you
Hi and welcome to FixYa, I am Kelly
I have been searching for a while now and know exactly why you came to FixYa for help. It is like a mystery as to where your primer bulb is even online!
Model number for the ST-155 is UT-20539-D
Look on the top or the bottom of the carb for a soft rubber button. Depress it not more than 2 times.
What is even more frustrating is... the carbs for this model are from 2 different manufacturers. One being ZAMA and the other being WALBRO. They are similar but the parts are not interchangable.
http://www.plattproducts.com/catalog_international_zama.pdf
I have been helping people for quite some time now and this was one of the most frustrating searches. Not your fault... Just the manufacturer seems to want the location to be a huge secret.
I tried to find an owners manual for the ST155 via company websites also.. no joy!
Thanks for choosing FixYa,
Kelly
Jun 13, 2011 | Garden
MY HOMELITE STRING TRIMMER UT21505 PRIMER BULB LEAKS. MY PARTS LIST DOE'S NOT SHOW THIS PART. CAN I PUCHASE IT OR DO I HAVE TO THROW IT AWAY
You can easily get a new primer bulb for it...most small engine repair shops will have what you need, and if you want, you can most likely snag one on Ebay....DON'T THROW IT AWAY, ok?
Jul 10, 2010 | Homelite Mighty Lite Lawn Trimmer
What is the right size trimming cord for the st 155
On the spool you should be able to find the size. Look for decimal sizes; .065, .080. etc... That will be the correct size...Lee
Apr 01, 2010 | Homelite Mighty Lite Lawn Trimmer
I need information on how to re thread a homelite string trimmer 155 i have not got a manual can you help
When you pull off the spool, look at the end of it. You will see an arrow pointing in the direction you wind the string. If you have two strings, they both wind in the same direction. Look on the body of the spool between the edges, on the barrel. You will see a hole or holes to start the string in. Good luck...Lee
Oct 20, 2009 | Garden
What is the gas oil mixture on a homelite st-155 string trimmer? sanlars14@aol.com
your trimmer should give yu th fuel ratio somewhere close to where you fill it. It will be in this orat- 50:1 forexample
Sep 12, 2009 | Garden
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
850 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
