Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
I have a emachine T5082
And it fail to launch ,( turns off when ever you try to start up computer)
  • 3 Answers
Might be a bad power switch have had trouble like this before
Posted on Oct 29, 2009
Emachines t5082- i pulled out the 512 mb chip of pc2-4200 533mhz that came in in the computer stock, and replaced with two 1gb chips pc2-4200 533mhz ( the computer has a max of 2 gb via two 1gb max slots)...
1)Check for BIOS update from emachines. Older computer may need updated BIOS to handle the increased memory.
2) If it does start up but the computer crashes or it will not load windows, Verify the sticks are error free with a memory diagnostic program like memtest. If the sticks have errors, get them replaced.
Mar 18, 2011 | E-Machines eMachines Desktop PC
I have a emachine t5082. I am trying to install new graphics card. How do i set the primary display to pci
Go into the BIOS, it will be in there...I don't remember where off hand, it won't be hard to find though.
Shut down your computer and wait for it to power down. Press the power button and look for a message that says "Press X to enter Setup." In most eMachines, this will be either the "F1" or "F2" key.
Dec 22, 2010 | E-Machines T5082 PC Desktop
I have an emachines t5082 and tried installing 2GB (2x1GB) they are a 2-pack, DDR2 6400's The board sees 1GB but when I put both in it won't even give me a boot screen or anything, just a black screen. Is...
eMachines recommends DDR2 at 533MHz.
(PC2-4200)
A lot of ram memory manufacturers, state you can use DDR2 at 667MHz. (PC2-5300)
This is a logical statement due to the fact that a lot of motherboard chipsets, (Northbridge chip specifically),
will allow ONE step up in ram memory frequency rate.
You are going Two steps up.
Who told you this would work?
This is erroneous.
(Mean that in a nice sort of way)
PC 6400 is DDR2 at 800MHz.
Your eMachines T5082 motherboard uses an ATI Radeon Xpress 200 motherboard chipset.
This chipset will only support DDR2 at 667MHz at best.
http://en.wikipedia.org/wiki/Xpress_200
Suggest you send that ram back, and get PC2-5300.
Jan 07, 2010 | E-Machines T5082 PC Desktop
I have a eMachines T5082 and have attempted to upgrade the RAM to 2GB (2x1 gb) PC4200. The problem is the computer will read either one or the other of the modules but not both at the same time. Any...
sorry, i re-read your post and saw that you are using 2 sticks,, if you have 4 slots for ram, insert one into the first slow, skip a slot and put the second stick in the 3rd slot, give it a try.
Dec 09, 2009 | E-Machines T5082 PC Desktop
Computer will not boot up
Sounds like the bios is not posting. Your motherboard could be damaged.
Try this though. Recheck that your keyboard and mouse are plugged into the right holes on the back, sometimes having these switched will not let the computer boot. Also, after switching them, unplug the power supply from the computer, and replug it.
Don't buy Emachines. Their power supplies are made to fail within the year. There are plenty of other 200$ PCs to buy.
The good news is, your hardrive data is fine.
Jun 24, 2009 | E-Machines T5082 PC Desktop
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
T5082 CF reader problem
If your comfortable opening the case, I would try disconnecting the reader from the mother board, and then reconnecting it. Sometime reseating the connections will fix it. Usually however the hardware is bad. If this is the case, you can get a replacement here
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=6082 IT's a little pricey though, may want to watch for the part number on Ebay.
Dec 31, 2008 | E-Machines eMachines Desktop PC
Installation windows xp emachine t5082
You must find "eMachine" XP USB drivers for your computer.
If all USB support is "enabled" in BIOS, the conflict is with drivers.
XP is loaded with many generic drivers, however eMachines is proprietary and requires eMachine drivers for most on-board hardware.
Contact eMachines support to locate the drivers (if available).
Thanks for using FixYa - a FixYa rating is appreciated!
Dec 14, 2008 | E-Machines T5082 PC Desktop
I have installed one 1gb chip into my emachines t5082 computer and it worked fine. So I got another and removed the original 512 MB chip from it and it won't recognize the second 1gb chip.
I'm assuming that your 2nd DIMM is the same type and speed as the 1st one you put in. If you are not sure, check and make sure that it is DDR2, 533MHz, PC4200.
If they are not the same, that is most likely the problem.
If both DIMM's are the same, remove them both and then put one of them back into DDR2 Slot 1. Start your computer and see if the computer recognizes the memory. Remove it and try the other DIMM in the same DDR2 Slot 1.
If both work OK, the problem is on your mainboard.
Dec 13, 2008 | E-Machines T5082 PC Desktop
Why won't drive d open?
This is a common problem with old or poor quality DVD/CD players. Try going to My Computer, right clicking on the drive and selecting 'eject'. I this doesn't work then just replace the drive and all will be well. If the drive is not shown in My Computer then you must assume it is dead.
Dec 08, 2008 | E-Machines T5082 PC Desktop
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
196 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
