I own a 2001 Land Rover Discovery II. Recently I've been having difficulty getting the key to turn in the door lock. Last night I couldn't get the key to turn at all so I entered through the rear door, setting off the alarm. When I got into the driver's seat and put the key in the ignition the key turned and the electrical system turned on but the car would not start. Is there any way to reset my security system and solve this problem?
Also check your inertia switch, under the hood. If triggered ; it cuts power to the fuel pump.
Normally by turning key in door lock this resets alarm also try passenger as well-owners manual should also give clues-try lubricating your lock with a can of triflow to free up tumblers also you may have poorly cut key or tumbler issues-if you can't find a can of triflow-wd-40 in a pinch.
Do you have remote door unlock/lock? Lube the key hole and insert the key a few times. The key should insert without any hangups. If it still hangs the lock tumblers are jammed and need to be replaced. There may be a latch problem as well.
