Question about Tomtom GO 910 GPS Receiver
Hi own a tomtom go910 i have managed to break one of the connector pins on the back of the unit and am therefore unable to charge it i have know idea of how or where to get a replacement please help
  • 4 Answers
Call 866-486-6866 tomtom support
Posted on Sep 26, 2009
Tomtom go 910 power connecter
Yes Chris it can be repaired. I do it all the time. The culprit is usually the negative pin. The negative pin is the gold pin on the far right hand side. With the unit upside down (you can see the contact pins on the board) and the lcd faceing you the negative pin will be on your far right hand side just below the reset hole. Doing it and telling you how to do it are two different matters.
Oct 15, 2009 | Tomtom GO 910 GPS Receiver
Specs GPS GO 910 Tomtom
yes it should come with a universal voltage adapter and eu two pin connector.
Apr 11, 2009 | Tomtom Go 910 (Europe, USA and Canada...
TOMTOM 910 will not turn on after charging
According to Kevin A who says, and thanks by the way (There is a reset button on the back at the top of the unit. It should be on the right side as you turn the unit around. Insert a paperclip or pin into this hole, and the unit should reset) at it works 100% because I tried this morning after being quoted £55 to have my GO910 fixed and now it works after the price of a paper clip. Doug rrp3
Nov 21, 2008 | Tomtom GO 910 GPS Receiver
Tomtom rider 1 not charging when on bike
TOMTOM are VERY aware of this problem. but deny it is an issue!
I had the same problem, they sent me a new shoe after weeks of emails. I told them that the shoe is not the problem, it's the connector on the back of the TT1. Because of the springloaded pins fitted to the shoe and the poor quality connectors on the TT the normal vibration on a motorcycle causes the pins to wear holes in the connectors on the TT causing intermittant connection.
As the cost of repairing or replacing these connectors is very high and there are a large number of units that would require this repair TT are ignoring it.
I'm now looking at a way of bypassing the connector altogether.
A temporary solution appears to be to smear the contacts on the back of the rider with a little petroleum grease or WD40 - seems to work for a couple of weeks at a time.
Sep 01, 2008 | Tomtom RIDER GPS Devices
Tomtom GO 910
Check your battery symbol.
On mine, the battery is dead (or mechanically disconneced inside).
You need to reset the unit by pressing the tiny button on the back.
Problem is that when you remove the unit from the charging stand, the dead battery does not allow you to press the reset button. (Pressing the reset button with no battery cannot reset the unit)
IF you could press the reset button while plugged into the charger, you could get you unit working again. But..alas, the design of the unit prohibits you from doing so.
Chances are if you fix the battery problem, you will have a usable unit again.
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
How to reset tom tom 910
the reset hole is hard to find... If you are looking at the back of the unit, it is in the upper right hand side of the liitle plastic protrusion at the top of the semi-circular opening above where you can see the exposed circuit board.
Mar 27, 2008 | Tomtom GO 910 GPS Receiver
TomTom go 510
COMMON PROBLEM SO FAR WITH THESE. IF STILL UNDER WARRENTY CALL TOM TOM THEY WILL REPLACE THE BATTERY UNDER WARRENTY
Feb 20, 2008 | Tomtom GO 910
Tomtom go910
Try cleaning the TT contacts with alcohol, make sure the unit is off when you do it.
Feb 08, 2008 | Tomtom Go Plus GPS Receiver
Tom tom go910 navi
the reset button is onthe back and you usually need a pen or pin to press it in. other than that confirm it is fully charged if it still isn't working then return it as faulty to the place you purchased it
Jan 08, 2008 | Tomtom GO 910 GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
113 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
