Question about HP LaserJet 2840 Printer
When printing it says "page too complex to print"
    Guru:
  • 174 Answers
To solve this problem begin with the below steps;
Press ENTER to clear the message.
Allow the device to finish the job, or press CANCEL to cancel the job.
Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
To access the Secondary Service Menu press the Menu button.
Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
Press Enter and then use the arrow key to go to Off and press Enter again.
Press the Cancel button twice to exit the Secondary Service Menu.
If the error continues to persist, contact Hewlett-Packard for technical support to troubleshoot the problem. Click here to go for more information about contacting Hewlett-Packard.
Thanks
Posted on Sep 25, 2009
    Scholar:
  • HP Expert
  • 199 Answers
Check the printing file size. Also check that USB high speed is set to "off" in the secondary service menu. Default is "on" and can cause this message.
To enter the menu press "Menu" key followed by the "2" key and scroll to the USB setting.
  • 525 Answers
Turn printer on.
On your printer, press the Menu button
Press 2 (on the fax dial pad)
Press the right arrow (next to Enter button) until you arrive at "High Speed USB.
Press Enter
Press right arrow to select "Off."
Press Enter.
Press Enter again.
The printer will reboot automatic.
I hope this help!
Posted on Feb 13, 2015
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
The normal reason for this message is.
1.It is possible to setup up a page, poster, graphic etc.which requires more memory than the prtr has on board. (You need more Memory)
2. If your driver is set for Vector graphics, try Bitmap( uses less memory).
3. Try a lower print setting.
Cheers
DeJudge
Posted on Sep 27, 2009
4 Suggested Answers
  • 624 Answers
SOURCE: Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Posted on Jan 05, 2007
  • 883 Answers
SOURCE: Page Too Complex Error
try sending a page with extremely little to print, such as one word...any change...I am suspecting printer memory overflow
Posted on May 30, 2007
SOURCE: HP LaserJet 2840: Page 'Too Complex'
Description
The device could not print the current page because of its complexity.
Recommended action
Posted on Apr 09, 2008
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    I'm trying to print its says page too complex
    A solution might be the proposed in this webpage:
    http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-Drivers/page-too-complex/td-p/88560
    Also, might be a problem with your driver, Download from HP website the latest driver available for your pronter model and intall it.
    At this webpage you have the procedure for some other model but it shold be basically the same applied to your model.
    HP Color LaserJet 2600n Page Too Complex Errors along with Blank Pages
    page too complex
    If still can't print, do a Google search for "PAGE TOO COMPLEX" and youll find more comments about issue.
    Oct 23, 2015 | HP Color LaserJet 2840 All-in-One -...
    The device will only print one page at a time.
    The usual 2 culprits are this:
    1. Not enough memory in printer for the complex document that you are printing.
    2. Newer version of Adobe Acrobat Reader installed but old printer driver installed. Updating your printer driver from the Brother Website will often improve printing performance dramatically.
    Aug 03, 2015 | Brother HL-2040 Laser Printer
    Lexmark E250dn Printer running slow almost half speed?
    Check the paper type you have set to print to. I the print thinks it is printing labels or envelopes it will run slower to ensure that it can bond the toner to the page. Also check how complex a print job you are sending. These units do not come stock with that much memory and a complex job (like a detailed photo) will slow them down.
    Jun 10, 2015 | Lexmark Office Equipment & Supplies
    Dell 2135 full memory error message cannot print PDF files.
    All three replies are incredibly stupid, but especially Frank's. The issue is simply that you're trying to print something that has too much complexity in it for the printer's pre-installed memory to store the final rendering of before printing. The way a laser printer works, unlike an ink jet, it has to take the entire page to be printed and render the final output in memory before the page can be fed through since it doesn't go line by line. If you're trying to print something that has a very complex page in it, such as a full 8x10 photo, the base amount of memory may not be enough. Dell sells a 256MB add-on memory chip you can put in the printer to get around this. Unfortunately the only other way around the issue would be to reduce the complexity of the page; perhaps try printing the PDF scaled down to 70% so the printed output is a lot smaller but also takes up less of the page, meaning the printer may be more likely to be able to fit the page into the existing memory.
    Nov 24, 2010 | Dell 2135cn All-In-One Laser Printer
    HP laserjet 5200 printer taking too much time to print a page..
    HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
    Try to send a test or a text page to calculate the difference.
    Also bare in mind that first page takes longer to print due to printer heat-up procedure.
    Nov 09, 2010 | HP LaserJet 5200 Printer
    I have a HP LasterJet P2015. I am trying to print multiple page PDF file documents and after one page has printed, the triangle and "!" light flashes and a print out says insufficient memory. How do I...
    Open Printer options and reduce the print quality. It is probably 1200dpi. Make it 600 and try the print again.
    You may also add more printer memory to print complex documents on highest resolution possible.
    Aug 06, 2010 | HP LaserJet P2015 Printer
    PCL XL error Error: InsufficientMemory Operator: EndPage Position: 152856
    Add more memory into your PCL printer -- each printed page is produced by your printer processing the PCL (Printer Command Language) commands. The page that you are trying to print is "too-complicated" for the printer to generate, giving the limited amount of RAM currently installed in the printer.
    Or, reduce the complexity of the page that you're trying to print.
    Aug 04, 2010 | Computers & Internet
    Page too Complex
    Sometimes you may come across this type of a problem when the device is not able to print the current page because of its complex nature.
    The speed of the USB on the product needs to be lowered. This can be done by turning off the “High Speed USB”.
    Given below are instructions to follow from the Secondary Service menu:
    Press MENU button to access Secondary Service Menu.
    Press the #2 button and use the < arrow to navigate to the High Speed USB selection. Press Enter > OFF > Enter.
    Jul 10, 2008 | HP LaserJet 2840 All-In-One Printer
    May 30, 2007 | HP LaserJet 2550Ln Printer
    HP LaserJet 2840 Printer Logo
    186 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
