The cable to the shutter has broken, causing the shutter to remain open - overexposing everything but low-light pictures. You can find a replacement cable on ebay...But it is far too difficult to install (the lens assembly must be disassembled, and the cable needs to be soldered). If you you handy, you can replace the whole lens, which includes the cable. You can find new replacement lenses in ebay for about $35.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
this is the only response that seemed to grasp the problem. Others said to reset which I have done several times before bothering any of the experts.
" - craigm341
Your camera might be set to a high ISO number. Change it to "auto ISO". It might also be in night scene mode. Why not try a camera reset? Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
My camera worked fine until about six months. Pictures outside are far too bright. Pictures with...
(More)
My camera worked fine until about six months. Pictures outside are far too bright. Pictures with flash and videos are ok. What can I do? I really like the camera and would like to find a solution. Pictures outside are almost white, pictures inside with flash are normal, also videos.
I can turn on the camera and it works w/out a memory card. As soon as I put in the memory card I...
(More)
I can turn on the camera and it works w/out a memory card. As soon as I put in the memory card I just bought, the screen goes blank and I can't get to any of the menu functions.
Is it possible for the camera or the charger to **** the life from my battery. I had a problem with...
(More)
Is it possible for the camera or the charger to **** the life from my battery. I had a problem with a battery so I bought a new one and now only 1 month later the new battery is dead also.?
