Question about Dell W1700 17 in. HD-Ready LCD Television
No pic, no sound
Just died on me recently. If I continously hit the TV/monitor button on the remote or TV while moving the mouse, the computer screen comes on for a second and then disappears. Weird. No TV whatsoever. I real piece of work this is to die after 4 years. Thoughts? Thank you.
  • 2 more comments
  • feelscrewed Jan 16, 2008
    just happened to me today. After speaking with Dell today, they told me that the only solution is a new t.v. After spending way too much money on Dell products, I'll go elsewhere.
  • Anonymous Jan 22, 2008
    My W1700 experienced the same problem today. I tried resetting it (holding the remote's power button down for 20 seconds), unplugged and replugged everything, still nada. No audio, no visual after the 1-second flash of the auto-test screen on PC mode. On to a newer TV - it's out of warranty, so Dell won't touch it. I did get some repair places recommended by Dell:
    http://www.moniserv.com/doc/lcdtv.html
    http://www.fixmymonitor.com/
    The first wants $120, but I'm not sure they can fix it? Too bad, it was a nice little machine while it lasted.
  • Anonymous Jan 28, 2008
    No pic/no sound, no power indication. screen is only 2yrs old
  • Rachiecp3 Mar 10, 2008
    I have the Dell W1700 monitor/television. My house was struck by lightening when I started having issues with it. The screen turns on and shows the test, then blacks out and shows the windows operating system for a split second, then blacks out again. I tried hooking it up as an external monitor from my laptop, same issues. Any thoughts?
    Thanks!
  • 46 Answers
The inverter is bad. Sometimes the logic will go bad due to 3-4 bad capacitors. www.lcdrepair.us will fix the unit for $59 and has a large selection of DELL Parts.
Posted on Jun 21, 2008
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
Using tv as computer monitor
Have the ps2 cable pluged into your tv from your computer. On the remote press the input button then slide through the screen until you get to the pc setting hit enter on the remote then follow the screen on the computer and tv.
Terry
Jan 25, 2014 | Proview Computers & Internet
Moved my pc and now the green light is flashing on the monitor. won't turn on. help! manual says to hit any button on keyboard or use mouse and it will come out of powersaver mode. mine does not
If you've moved your whole PC recently then you might need to make sure that the VGA cord is connected to the correct output on your computer and is screwed on tight. If that doesn't work then try replugging it.
Mar 01, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Por error desconcete el sonido del monitor y no
My Dell monitor screen goes black after I move my mouse around to get on my computer. The screen goes black and I have to hit the button on the screen (that lights up the screen) about 18 times until it finally stays lite. I don't get it, if there is a problem with the light why does it stay on after hitting the light button several times?
Patty
Dec 29, 2009 | HP Computers & Internet
When I move the mouse off the side of the screen
Try changing the screen resolution of your screen
Aug 19, 2009 | Apple Computers & Internet
Tv stays on after hitting the power button and remote stops working
it prolly is turned off but the image is burned into the screen
May 25, 2009 | Panasonic PV-C2020 20 in. Combo
No picture on tv
Move your mouse over to a empty part of the desktop and press the right mouse button. Select properties.
Make sure that your tv is connected to the computer, that it is turned on, and that it is set for line input on that device.
Select the settings tab. You should see this box appear.
Monitor one is your computer monitor. Monitor 2 is your tv. It should be greyed out. If you move the mouse over to 2 and press the right mouse button make sure the attached is checked off. If not do this right now.
You may have to click on monitor two as well and select the advanced button on this screen. Then look in the settings to turn the tv on (this happens with ATI cards, NVidia cards may have a similar setting as well). Once it is turned on and you hit apply the picture should come on the screen. If you check off extend windows desktop onto this monitor, you will only see the desktop without any icons. Make sure that feature is disabled when you use monitor 2 (by default it is).
This should keep you busy to get it to work. Let me know if you need anymore assistance on this.
Feb 14, 2009 | XFX GeForce FX 5200, Graphic Card
Dell m992 screen problems
If you notice, when you see the windows start screen, its usually "big and dopey". Thats because the video drivers aren't being used yet. If it is blanking out right after you see that screen (with the scrolling bar), my guess is it's a corrupt / bad video driver.
Was any other hardware added recently?
Jan 10, 2008 | Dell M992 19" CRT Monitor
Dell W1700 17 in. HD-Ready LCD Television Logo
83 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
