Question about GE GSS25LGM Side by Side Refrigerator
Where is the defrost timer located on side by side models. Is it on the curcuit board on the back?
  • 193 Answers
It should be part of the motherboard on back of unit
Posted on Oct 03, 2009
  • 612 Answers
It is the board in the back. They have started integrating them into the board. You are most likely familiar with the old style that you can advance, you could find them either inside the control panel or under the front. No one makes them like that anymore. But were they not much simpler and cheaper. Your part is $150.00 where if it were one of the old style it would be around $30.00. I hope this helps.
Ha, sorry but you asked. Have a great day and, Good luck!
Please rate solution
Posted on Sep 25, 2009
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Defrost timer
The defrost timer is part of the electronic control baord located on the back of the refrigerator. If the freezer is not defrosting check the thermistor on the evaporator(freezer) coils. It can cause the control board to thing it doesn'y need defrosting. a common problem
Mar 22, 2014 | Kenmore Side by Side Refrigerator
I need to find the defrost timer on my whirlpool ed25dqxyn02
Your model does not have a defrost timer, but a control board. The board is located on the back of the fridge behind an access panel.
Mar 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the defrost timer located on a G E side by side frig?
Your fridge does nt have a defrost timer. For the model PSS26MSRSS you will need a main board linked below.
Thanks for asking.
Main board
May 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side stops defrosting.
has the defrost timer been replaced? if not, that'd be the next step. there are only a few parts in that line: the power, the sensor, the timer, and the heating element. also, if the condesate drain is plugged, water stays pooled under the coils and freezes again.
Aug 27, 2009 | Refrigerators
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
The fridge has power. But the temperature control has no power. I have a G.E. side by side. model # gss25tgpa
Check the defrost timer. It may be stuck in the defrost position which would give you no power to the temperature control. Locate the timer and rotate the clutch head screw clockwise and you should hear a click after which the compressor will start and there will be power to the thermostat.
May 24, 2008 | GE Refrigerators
GE GSS25LGM Side by Side Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
