Question about Dualit CTS4E 4-Slice Toaster
The cord on the dualit and plug gets really hot when in use
  • 1,711 Answers
One of the heating elements or more probably is faulty. They need to mesure by an ohmeter all elements and replace the one or more that is faulty.
You must do fast since you can expand the damage to other parts also like timer and cost for repairing it will be much more not to mention also the risk you have using the toaster in this condition.
So please have it checked.
Posted on Sep 02, 2010
How to remove plug on dualite toaster
plugs on electrical appliances are moulded onto the wire so to remove a plug , you cut it off
AS you had to ask ,it would be a safe move for you to take it to an appliance repalir shop and have them fit the new cord
Jan 15, 2018 | Kitchen Appliances - Others
How to polish the outside of a dualit toaster
To clean the outside of a dualit toaster? If it is plastic, I would use soap and hot water. Only with a wash cloth any other (such as a scrapers, scouring pad, sos pad) are to hard on the plastic and will leave scrap marks. If it's an aluminum toaster I would use a cleanser like (aluminum cream or spray) to clean it. And the toaster will look like new.
Jun 01, 2013 | Dualit 20247 2-Slice Toaster
Cannot take dualit plug apart
Remove the small silver Dualit sticker from the pin side of the plug. There is a small screw inside that will undo the plug :)
Apr 04, 2012 | Kitchen Appliances - Others
I need to replace the power cord on a Dualit 4 slice toaster model 40418, where can I buy this ?
This an ordinary cable that you can from electrician shop or DIY shop nothing specal. Just cut a piece so hey will give you the same size
Jul 23, 2011 | Dualit 20247 2-Slice Toaster
I cannot get the cord on my Dualit mixer to come out very far.
The cord has twisted inside the housing and is now binding or it has slipped out ofthe housing and is wedged between the cord housing and the case. If it is still within warranty, send it in, if not, you'll need to carefully open the housing to get the cord into the cord housing.
Nov 20, 2009 | Dualit 88520 240 Watts Hand Mixer
Acer TravelMate Laptop, cord getting hot, not getting power
I would imagine the voltage regulator in the adapter brick it dying...it will fry your motherboard if it starts throwing off power spikes. laptops need good consistent power flow of the right voltage. Buy another adapter.
Sep 05, 2009 | UltraLast ULAC3660L For Acer Aspire...
Dualit 889 espresso maker leak
my machine did the same.... i just descaled it and gave all the parts a really good clean and it seemes to solve the problem
Dec 30, 2008 | Dualit Espresso 889 Espresso & Coffee...
measure and record the resistance of the elements. attach an ohmmeter to the (unplugged) power cord and push down the toast loading mechanism. wire the elements up until you get the same reading on the ohmmeter you got when ohming the elements out individually. Then make sure the ohmmeter reads open when the toast loader mechanism is deactivated. Then make real sure that the hot side of the ac power plug (the smaller plug) is not electrically connected to the case of the unit. Take the unit outside on a fireproof base and run an extension cord to it but leave it unplugged. Better yet use a switching power socket if you have one. Load it with toast and actuate the toast loading mechanism. Stand away from the unit and power it up. You may want to run it several times to eliminate any smoke from it due to contamination. Be aware that any finger acids or other contaminants on the elements will shorten their lifespan so you might want to clean it and let it dry thoroughly before use.
Nov 18, 2007 | Dualit Vario Combi 2x2 65-Slice Toaster
Dualit CTS4E 4-Slice Toaster Logo
192 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
