Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Lcd gets garbled everytime i use the charger
Everytime i connect my laptop to its charger the lcd gets garbled. its a satellite L200
  • 700 Answers
Might try to check the voltage output of the power supply pack if within spec or maybe your power supply is at fault. Try other suited charger for your lappy to test.
Posted on Sep 25, 2009
My Toshiba L200 when i plug adabtor it always shut down. if i use with battery is use normal but when plug adabtor it shut down,what can i do?
First double check your charger is 19V (at 3.42A minimum) on the body label. It could also be providing a faulty voltage so you need to check its output with a cheap voltmeter (should be 19 to say 22 volts off load), OR borrow a 19 v charger from someone which has same connector to see if it works on your laptop. Good Luck.
Dec 23, 2014 | Toshiba Satellite A305 A355D L200 L305...
Toshiba satellite battery won't charge
DID YOU NOTICE ANY OVER HEAT IN BOTH,THE PC OR CHARGER? IF SO THE CAN BE 2 ISSUES.
1-THE CHARGER
2-THE BAT
IF YOU TRY TO CONNECT THE CHARGER WITHOUT THE BATT,THE CHARGER GET HOT? (1) ,DO THE CHARGER IS OK (2)
Apr 26, 2012 | Toshiba Satellite A65-S126 Notebook
My laptop hangs everytime i use the power supply (adp-75sb ab) provided for this unit (toshiba satellite a205-s6808) but when i start my laptop with the battery, everything works out fine. it only hangs...
Check the voltage output from the charger and see if it is within the range that is stamped on the charger body (eg: 20 volts) If it is below or above this, then the charger is faulty. If the green light is flashing on the charger, it means that power is "not being accepted" by the laptop and this indicates a faulty charging port / circuit.
Jan 18, 2011 | Toshiba Computers & Internet
Help Me Please...my Toshiba A45-S151 Screen become garbled, seems like my LCD lost its black color....the screen display blur line,, and has no black colour.... it happens after i dissamsembly my laptop
Check the Wire Harness make sure it is back in the correct place and plugged in all the way into its designated plug. :) also, if that doesnt work then you can replace the LCD. Which is expensive.
Apr 14, 2010 | Toshiba Satellite A45-S151 Notebook
Gabriel175: Laptop now boots and video heatsink/fan now running but screen is "garbled" with horizonal lines. Will attempt re-connecting the screen cable.
To determine if the LCD is faulty or the video card, connect an external monitor to the video port on the laptop, power up the external monitor first then the laptop. The video data will divert to the external monitor automatically and if you get a normal Windows image the the video card is OK and the fault is the LCD screen or video cable.
Jul 30, 2009 | Sony VAIO VGN-S170 PC Notebook
Toshiba Satellite A135-S4527 Charger problem
Get another laptop.
The A135 is a lemon.
Problem is either with the dc jack on the board or more than likely the motherboard is damaged.
I've repaired a number of A135's and 95% of the time motherboard had to be replaced.
Sorry for the bad news, but I hope this helps.
Mar 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite laptop won't start
From Toshiba Manual:
"Over a period of time, and depending on the usage of the
computer, the brightness of the LCD Screen will
deteriorate. This is an intrinsic characteristic of LCD
technology.
Screen will dim when the computer is operated on
battery power and you may not be able to increase the
brightness of the screen.
Try pushing Screen contrast to Max when on AC charger connected.
Allow several hours charging battery with PC off.
If battery does not completle charge Or if older than 3 years CHANGE it.
Jan 04, 2009 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite L200 version of Laptop with OS vista
some keys in my laptop toshiba l200 suddenly stopped without any reason so i want to know how can i fix it and if may be infected by virus
May 19, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
203 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
