Question about Whirlpool Duet GHW9150P Front Load Washer
DOOR LOCKED TIME REMAINING AND DOOR LOCKED NO CODE ERRORS. TRIED UNPLUGING STILL NOTHING?
  • Anonymous Jan 07, 2008
    door locked with cloths in machine and can't open the door and their is no error code
  • 89 Answers
The door lock asbly. needs to be replaced. You may want to pay a pro to do this as it is a tricky job to do. GOODLUCK
Posted on Dec 16, 2007
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
