Question about Cameras
Canon powershot s500 will not switch to playback mode when I push the switch it doesn't change the mode always in shooting mode Help
SOURCE: canon powershot g3
a common problem is with the 'optical unit' shutter control part.
have to replace the 'optical unit'
Posted on Jan 31, 2008
Benimur
  • 6966 Answers
SOURCE: Camera Buttons on back do not work
Possibly two (2) reasons:
1. Software/firmware glitch. Reset the camera by removing the battery;
2. One of the buttons is stuck preventing any other from working. Determine which one and tap on it a couple of times as a temporary workaround. Ideally, the unit must be opened and the contacts/ switches cleaned with contact cleaner.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 16, 2008
SOURCE: Lens does not retract in play back mode
Never buy a Canon camera again. I have the same problem, and sorry that nobody has a solution. This is the worst of the 3 Canon digitals I have purchased. Lack of a view finder makes it impossible to preview shot when outside on a bright day.
Posted on Jun 29, 2008
SOURCE: Canon PowerShot A75
If you get a blank screen and the camera is on,there are two ribbons to the LCD one (the smaller one) is power to the screen. the larger ribbon is the data lines. If the camera is on the problem is a loose connection of one or both of the ribbons. Hope this helps Jerry
Posted on Sep 30, 2008
t00nz
  • 4738 Answers
SOURCE: at different times my Canon
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Sep 19, 2009
Playback switch does not operate
PDF]Camera User Guide
gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
camerarepair.blogspot.com/.../simple-fix-for-dead-cameras-that-wont.ht...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
Mar 16, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon powershot only boots in playback mode
You could try to help the lens coming out if you hear the motor trying to. Or hold the camera with the lens downwards to let gravity help as well. Hope that will help. Or the lens mechanism will be faulty and the whole lens needs to be replaced. But such a repair might not be worth it because of the costs and the value of the camera.
Jan 04, 2014 | Cameras
Hi, I have a Canon Powershot A700 digital camera and I am facing a problem with it. The 'Mode Switch' button, which changes the mode from Shoot/Record mode to Play/View mode is not working....
If you have the manual for this camera turn to page 15.
This tells you how to switch between Shooting Mode and Playback Mode.
This is achieved simply by pressing the DISP button.
This button is located below and to the left of the FUNC/SET button.
Pressing DISP repeatedly toggles between Shooting Mode and Playback Mode.
I would suggest you try these steps with your Mode Switch in both positions alternately.
May 20, 2011 | Canon PowerShot A700 Digital Camera
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Preview mode not working and lines on the screen
canon ixus 500.
when i switch mode to playback/preview it doesnt work so i cant view pics that are taken or can i upload them to my pc.
Jun 28, 2008 | Canon PowerShot S500 IXUS 500 Digital...
S500 Kept displaying pictures in shooting mode
Navigate the the rotating knob to manual or auto mode then shoot it then ok.
Dec 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Nov 12, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Powershot S1 IS trouble shooting in images of lcd monitor
Try playing back pictures you know were captured properly ( either with another properly working camera or with your camera before the problem with quality has appeared ). If the image is ok in playback but 'noisy' in capture mode then the CCD sensor is faulty /on its way out. Ask Canon if they repair CCD faults on this model free of charge.
Aug 18, 2007 | Canon PowerShot S2 IS Digital Camera
Not Switching between Shooting and Playback
well depeneding where you live, you should call canon and find out where the nearest canon store and you can also ask them how costly the repairs will be... i doubt very much seeing as it is an internal problem... but ask just the same...:D
Aug 29, 2006 | Canon PowerShot A75 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
