Question about Panasonic Televison & Video
I have 17" Panasonic Model No. TC17La1 it is not connected to cable, i purchase a antenna but unable to get any station, I did the menu option Channel search but only receive one Channel and that was not very clear, do i need a converter box for this TV
  • charlesh402 Sep 25, 2009
    THANKS SO MUCH FOR YOUR PROMPT RESPONSE.
    Scholar:
  • 146 Answers
This is what Panasonic has to say about your TV:
"If you use an antenna, indoor or outdoor, to receive over-the-air broadcasting, and your LCD TV is older than a 2006 model or is a 2006 model with a screen size smaller than 26", then you will need to purchase digital converter box."
Posted on Sep 25, 2009
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to antennaweb.org and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
Aug 24, 2016 | Olevia LT26HVX 26 in. LCD Television
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
Purchased second hand 17/3/2011 (2007 model) plugged in power turned on power and plugged in antenna, box comes on screen saying"no sgnal" Antenna was already working another TV.
Based on the information you gave you will have to check/verify several things.
> You have connected an antenna.
> Go into the menu and set the signal input source to antenna/air or whatever its called. The previous owner may have used cable.
> Scan in the channels the antenna will receive.
> Save the list of channels.
You should now be able to watch stations via the antenna !!
Mar 25, 2011 | Televison & Video
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Dec 06, 2010 | Televison & Video
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
Jul 25, 2010 | Philips FTR-9964 Tuner/Receiver for Plasma
17 in. trutech tv unable to get channels except 2-13
For channel setup you will need to;
1) Connect the signal source to the back of the set.(Antenna or Cable)
2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
3) Go to the auto program/scan menu and run it. This may take a few minutes.
Now the channels may be watched.
Mar 16, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Feb 23, 2009 | Samsung Televison & Video
Off air antenna hook up
You probably have to set the tv to run on the input jacks your antenna is plugged in to. In other words these newer tv's have 2 or 3 inputs and they only run on the input it is set on, if not the right one you must change the setting. On mine there is a button next to the on/off button on the set which is inputs, keep pressing that button and it cycles through inputs till you get the right one. When tv first comes on it flashes the name of the current input on the screen--think they all do that. If input is hdmi, it refers to the hdmi socket, if composit (I think) then it refers to the rca jacks that are red, white, yellow, may be more than one of either. In this way you could have cable on one input, a video player on another, and cable on still another by switching desired input. I use a UHF antenna but it didn't work till I got the right input and then searched for stations studying the menu for station setup, have to set up the stations first, it will configure settings for each station, and have it do that before you can expect to find and receive stations. With correct input you should get a blue screen or something with printing if input is right, click your menu button and will see the menu and then find where to configure stations setup, otherwise it is totally black and nothing happens, nothing responds, that's the wrong input.
Jan 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Antenna for my HDTV
Special HD or Digital antennas are not required to receive digital stations. A good VHF/UHF antenna should work. Try an amplified antenna for the best reception. Most antennas have a coax type connector which should connect to the ant. in jack on the back of your DirectTV box or to your tv depending how the box is connected to your tv.
Jun 25, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
