Question about Hotpoint Aquarius WF000 Front Load Washer
Water will not drain from hotpoint WF620P
Water will not empty from my hotpoint WF620P washing machine. I have taken off the kick plate at the front but do not know how to get to the filter to check it. Can anyone tell me how to do this or do I need to call out a plumber????
  • spaul_25 Dec 11, 2008
    yes please tell me
  • Anonymous May 17, 2009
    water will not drain from my hotpoint wf620p
  • 89 Answers
Ya need to find the water pump. It will have two hoses going to it. Pump may have a pen or someting stuck in it and wont let it turn. goodluck
Posted on Dec 16, 2007
I have a hotpoint bwm129 1200 spin and I can't drain the water out of the washing machine. I have taken out the filter as it was clogged, cleaned up but the rest of the water has not come out of the d
You should be able to drain the water out by laying the drain hose down into a bowl. Does the pump function properly on final spin, that usually clears the water to allow the door to open. Parts are obtainable from Hotpoint
Jan 29, 2015 | Hotpoint BWM12 Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint WD61 - I have taken back off, emptied blocked filter but having reasssembled the water does not drain and therefore does not spin. If I empty water via a bucket from drain hose the machine does...
hello, is sound like the pump not energizing the pump needs testing with a multimeter. fill it up again then empty it you should hear the pump kick in also check the hoses make sure there not kinked good luck
Dec 05, 2010 | Washing Machines
My Candy CNV 256 will not drain propery. I am
there is a pump filter at the front behind the kick plate . Turn machine off at wall . put towel's on floor remove kick plate with screwdriver carefully not to damage plate .remove screw from filter (if one is fitted )place shallow tray on floor under filter (baking )and carefully turn filter front there is always water in this part turn and pull gently water will now be filling the tray and towel's are getting wet clean filter and refit hope this works .post again if not
Feb 22, 2010 | Washing Machines
Few12 will not spin after washing, any ideas
Had the same problem. Removed the kick plate at front and unscrewed filter. In the filter recess I found a cotton wool bud. Appeared to have stopped the blade like fan spinning which appears to push the water into the drain hose. Works perfectly now.
Aug 19, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wm75 drain pump removal
soz didnt realise it was a wm75 .unplug machine and remove lower back panel.remove water and take off hoses.pump is secured by 2 phillips screws underneath.remove wiring block and after removing pump there is three t15 tox screws on pump housing. sounds like u have something obstructing pump impeller
Mar 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
My washer is stuck on f/o5 with water sstill init is a hotpoint ultima super silent
there is a blockage. to get the water out put the end of the drain hose into a basin lower than the machine. you may have to shake it about a bit to get the water flowing.
you will need to check the filter or pump for foreign objects.
these may be at the front behind the kick plate or the rear behind the lower panel.
Feb 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint few 12 first edition
Its either behind the kick plate or in the pipe which runs from drum to pump at the drum end.
Dec 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hotpoint Aquarius WF000 Front Load Washer Logo
174 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
