Question about Panasonic TH-42PX25U/P 42 in. Plasma HDTV
Where can I download panasonic tv firmware? - Panasonic TH-42PX25U/P 42 in. Plasma HDTV
I need a firmware for Panasonic TH-L32C20X LCD TV, Software Version: 1140 Can you help me, Thanks.
sounds like you need a technician but try the panason website and support you will need a pc and sd card
http://av.jpn.support.panasonic.com/support/global/cs/tv/download/fw/europe/step3_eu.html
Dec 17, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
My Panasonic tx-l37s10b hdmi ports are not working at all I changed all the leads and not one of the 3 ports work! I want to get this fixed so I can use my chromecast on this tv ! HELP PLEASE
Try updating your televisions firmware, download the firmware from the official Panasonic website and follow the instructions to the tee.
Dec 21, 2014 | Televison & Video
I am trying to install a firmware update on a panasonic viera TC-P50S1 and the TV keeps trying to read photos on the SD card instead of reading the update files. what am i doing wrong?
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Firmware update procedure to many popular brand TVs are given in detail with screen-shots.
Jan 28, 2014 | Panasonic VIERA Televison & Video
TV screen goes blank, still have sound. Is it our freeview box or the TV.
There are some firmware updates available for the DMR-XW380 that you might want to consider at least looking at.
http://panasonic.jp/support/global/cs/dvd/download/xw480/index.html
May 16, 2012 | Panasonic Viera TC-37LZ85 LCD TV
Is there a firmware update for panasonic dmr-e75vp
It is possible to update the firmware on your unit, provided that the firmware you download is not already installed on the machine.
In order to install the firmware update you would need to :
1. Visit Panasonic's website at Panasonic.com
2. Click on the 'Support' link and then type in your Model No. DMR-EH75
3. Click on 'Drivers and Downloads'
4. You may download the firmware by clicking on the 'Download' link
5.After the firmware has been downloaded, you will need to burn the file unto a CD-R
6. After successfully creating the Firmware disc, place the disc inside the unit to begin the update process
7. The unit will indicate when the update process is finished
8. There is also further detailed instructions on the 'Download instructions' link which is found beside the 'Download' link.
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EH75VS.D#ts
To obtain additional troubleshooting assistance for your product, please contact our Panasonic Customer Call Center at (800)211-7262. The hours of operation are Monday through Friday 9AM to 9 PM. Saturday and Sunday 10 AM to 7PM Eastern Standard Time. A representative will be available to assist you. Please have your case number, which is listed at the top portion of your email, available at the time of the call.
Aug 24, 2011 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DMR-XW350 Network enabling firmware Upgrade.
The web page seems to have a problem in its Javascript that jumps to the page for each location.
You can get around the problem by editing the support page URL, just replace index.html at the end of the URL with one of the options:
For example for New Zealand, change the index.html to nz.html: so the following
http://panasonic.jp/support/global/cs/dvd/download/xw350/index.html
is changed to:
http://panasonic.jp/support/global/cs/dvd/download/xw350/nz.html
The options in the Javascript are listed as follows:
<option value="au.html">Australia</option>
<option value="nz.html">New Zealand</option>
<option value="uk.html">UK</option>
<option value="fr.html">France</option>
Feb 27, 2010 | Panasonic Televison & Video
DMR-EH50 DVD Loss of TV Guide and Auto Time Update.
http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP
the firmware and instructions are located there.
Jun 26, 2008 | Panasonic DMR-EH50 DVD Recorder
Won't respond to volume or channel changes red light blinks 20x's when turned off.
It's definitely a firmware problem. I called Panasonic and they were very polite about the entire situation and sent me a SD card with the firmware update. If you don't have time and you're tired of listening to tv at the same volume there is a way to do a hard reset.
I figured that unplugging the unit would do this, but there is one other step that you have to do to ensure that this works.
Generally the power button on the tv is always in the "on" position, this is what allows the remote to work. In order to do a hard reset the on/off button must be in the off position. Make sure that is off, then unplug the unit, let it sit there for a minute or two and plug it back in. If the tv comes back on as soon as you plug it back into the wall/powerstrip then the button was not in the off position.
This isn't the best fix, you'll still need to get the firmware update but it will at least give you the ability to use your tv normally....well until it decides to randomly lock up on you again and you have to do this all over.
May 11, 2008 | Panasonic TH-42PX60U Television
Tv does not power on
If it blinks 7 times, your power supply is shot
If it blinks 10 times, a video board went bad.
Mar 28, 2008 | Panasonic TH-42PZ77U TV
Panasonic TH-42PX25U/P 42 in. Plasma HDTV Logo
162 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
