Question about Dell 3010cn Laser Printer
I need new parts for my Dell 3010 printer. Whenever I print now, there is massive streaking down about a third of the page, focusing on the centre. Is this likely to be a new fuser or some other part replacing?
  • 400 Answers
First try to replace the cartridge and then if you can see the fuser make sure there is nothing on that area causing the streak.
Posted on Sep 25, 2009
Samsung ML-2510 printer: how many copies should I be able to print at one time. After 100 copies the printed page has a faded streak down the centre. Does my printer need a cooling off period after so...
The laser printer "shouldn't" need a cooling period from printing. Sounds like you do a good deal of printing with it,. Depending upon the quality of the printer you may need to break down the number of pages per print and see if that works.,. however, my best guess is that it needs a real good and perhaps regular cleaning...
Best regards
Ck
Oct 21, 2011 | Samsung ML-2510 Laser Printer
My dell 1720 printer prints streaks on the right side of every sheet. i replaced the toner. No change.
Remove the toner and the paper tray and open every door on the printer. Take a can of air and blow out every nook and cranny in the printer. Check and carefully wipe all rollers. There a fuser kit in the printer, likely in the back. If you feel comfortable with it, remove the fuser kit and use a can of air to continue cleaning. Reassemble the printer and run a few test pages, it may look like a bigger mess for the first few pages (up to 25). However, as you run the pages the print should clear up. If you still have a streaks on the pages, you will likely need to order an maintenance kit from dell. This kit should include the fuse, rollers and other replacement parts for the printer.
I hope this has helped you
Aug 31, 2011 | Dell Laser 1720 Printer
Streaks in printing with my HP officejet L7680
It could be paper dust on the paper. Try putting some new paper in the printer to see if that fix it.
Aug 13, 2009 | HP Hewlett Packard Officejet Pro L7680...
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
Streaking when printing
If it's not the Cartridge, then it's almost positively the fuser, which will cost more than a new printer to repair
Mar 12, 2009 | Samsung ML 1610 Laser Printer
It prints vertical lines where the text is.
check your drum unit. The toner cartridge mounts into the drum which can be permanently charged causing a constant streak to occur.
Solution:
Remove the toner and drum unit. Clean them off with a non-fuzzy non-rough cloth or paper towel. Pay particular attention to where the streaks are in relation to the toner cartridge and drum. If you clean it off and you still get streaks check whether they transfer from the toner or just from the drum.
There may be a way to discharge the drum, otherwise you need a new drum.
Feb 27, 2009 | Dell 946 All-In-One InkJet Printer
How to solve repeated paper jams in Dell 3010 laser printer
Replace the pick rollers. If you're out of warranty it'd be mighty expensive to have Dell replace them, but, if you call them, they can get you access to a website (I can't remember the name...sorry) that has walk through tear-downs with pictures of each and every step. (Only do this if you're handy and have time)
Otherwise, replacement is the next option.
Typically Jams on this unit are from worn rollers. :)
Good luck.
Oct 20, 2008 | Dell 3010cn Laser Printer
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Dell 3010cn Laser Printer Logo
133 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
