Question about EdgeStar Portable Air Conditioner Heater
I have an edgestar portable air conditioner model no. ap410hs that is flashing an e1 error code. I have cleaned the filters.
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Posted on May 06, 2008
ginko
  • 19396 Answers
SOURCE: EdgeStar 400S portable AC
  • Make sure the air filters are not dirty.
  • Make sure the air inlets and outlets of the indoor and outdoor units are not blocked by objects.
  • Make sure the temperature setting on the remote controller is appropriate.
  • Make sure the doors and windows are closed.
  • Make sure the air flow and direction settings are appropriate.
  • Make sure ventilation fans in the room are not operating.
Posted on Jul 24, 2008
  • 143 Answers
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Posted on Jul 25, 2008
6ylucy
  • 742 Answers
SOURCE: boston innovative products MOB 10KDCHR portable
i found the user manual for it at:
manualfox.com/link/bostoninnovative.htm
Posted on Feb 13, 2010
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
What does E1 mean on portable AC
E1 "Error Code" means different things with different appliances and you need to give a specific Make and Model of AC..
It should be explained in the troubshooting section of the user's handbook..
"Clean Filter" is a common routine message..
Oct 19, 2014 | Heating & Cooling
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
My edgestar portable unit smells like miuldew when running. What can I do to clean it
First, start by cleaning the air intake filter. This alone can make a significant difference. Check the exhaust hose(s) for obstructions. Also make sure that the hose(s) are not drooping to much. As this will trap moisture in the hose(s), rather than exhausting out the window.
Hope this helps you and thanks for choosing FixYa.
Aug 19, 2011 | EdgeStar Portable Air Conditioner ...
My Edgestar AP410HS triggers the circuit breaker in the circuit box outside the house after it's been running a few minutes in air conditioner mode. This is new, it hasn't happened until a few days...
Breaker tripping likely from a loose or bad connection. Wire is getting over heated from not being tight. CAREFULLY INSPECT ALL CONNECTIONS. Including inside the disconnect box outside. Possibly even a bad breaker. HIGH VOLTAGE IS DANGEROUS , if even the slightest bit nervous, call a professional! Good Luck
Mar 29, 2017 | EdgeStar AP410HS Portable Air Conditioner
Turning off code e1 flashing what is e1 code
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
I getting a E7 code
Check the water resevoir and empty it. If its already empty check the level sensor.
Jun 23, 2010 | EdgeStar AP410HS Portable Air Conditioner
Stopped pumpin heat displays E7
Follow the link below to find the information about your unit. Also, if you can't find the information that you need then they will have a way to get you the tech support that is brand specific.
http://www.edgestar.com/support/portableac.htm
Mar 20, 2009 | EdgeStar AP410HS Portable Air Conditioner
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
EdgeStar Portable Air Conditioner Heater Logo
61 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
