Question about Vivitar ViviCam 5385 Digital Camera
The latch to keep the batteries in is broke - Vivitar ViviCam 5385 Digital Camera
My Coolpix S6100 battery latch broke. Can I get a replacement?
As of Sept 2 2016 there are several for sale on eBay, for about 7 dollars to about 12 dollars.
Search for "battery door", not battery latch.
Sep 02, 2016 | Nikon Coolpix S6100 Digital Camera
Can I replace the latch or change the full internal chamber?
sir,
this part is available with Nikon agency, to replace this you have to open the whole camera, then detach the front portion, it doesn't matter, just a piece of rubber or sponge fix on the battery lid, this will be help full to hold the battery at contact perfectly.
Jan 09, 2016 | Nikon 1 J1 Digital Camera
Broke hood latch on 94 voyager, can not get to cable to pull on. What can i do to open hood.
That is a problem, have to try and grab the cable from under the dash or behind the grille, try to see how it pulls the latch and get a screwdriver in it to release it wont be easy, keep oil or something on it to keep latch working free after getting it open....
Oct 03, 2010 | Dodge Caravan Cars & Trucks
I havve a nikon S51 the battery latch is broken
they can repair/replace according to the damage and how it broke off. if the door broke into pieces it will be replaced. Replacing is done 99% of the times since it offers the pressure the battery needs to continue to charge well.
here is a discount code if order is placed today june 3rd, MD2010 - promo link: www.teleplancamerarepair.com/md2010.asp
non promo link; www.teleplancamerarepair.com
Jun 01, 2010 | Nikon Coolpix S51c Digital Camera
My battery latch is broke. How can i get this
Found it on ebay, Item number: 360464140454
Apr 18, 2010 | Sirius STILETTO 100 MP3 Player
I need to know WHERE to get a battery latch.
call Nikon parts replacement for a new latch, It's easy to install
Nikon Parts Department
7AM - 3PM (Pacific)
Monday - Friday
310-414-8107
Fax- 310-322-6979
Mar 07, 2009 | Nikon Coolpix S210 Digital Camera
2002 FORD Explorer J that keeps the door shut broke
Are you sure the latch broke? sometime they can freeze up and hang unlatched. The part that latches the door to the striker is "C" shaped. If it is flipped into the latched position with the door open, it won't work. If this is the case, use a screwdriver and pry the latch to the open position while pulling the handle. But if it is broken, yes it can be replaced. Usually torx or allen screws in the end of the door. Pull the door panel off and pop the rods off before you unbolt it though!
Dec 23, 2008 | 1994 Ford Explorer Limited
Battery latch
R707 and R717 uses essentially the same parts. You can find one for repair on Ebay. You can obtain the battery latch from there.
Sep 10, 2008 | HP Photosmart R717 Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Battery door and latch broken
Have used a 5-cent nylon cable tie for years on our CoolPix 990 and it never has failed, and still allows for battery changes. Looks a little funny to some, but is very functional. Don't know if your camera's design is similar enough for this to work, but it may worth trying.
Oct 29, 2007 | Nikon Coolpix 3200 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
13 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
