Question about Talon Electronics - Others
Rebuild engine - Manco Talon 4 wheeler
My son blow up the Manco Talon 4 wheeler yesterday. I am wanting to rebuild the engine as I don't have the funds available to replace it right now. He and I will now have a fall project to complete together. I have no idea where to start or what I need to get started. My husband thinks the son blow a hole in the piston as the engine made a loud bang sound and then lost all engine compression. Any assistance, guidence and encouragement is greatly appreciated.
  • cathy_hollan Sep 25, 2009
    Will the service manual show me step by step or will I have to muddle thru on my own?
  • Samuel Charles Spriggs May 11, 2010
    This is an extremely difficult task for a first-time "overhauler". But it sounds like you're motivated. First step is to acquire a service manual -- chances of getting it right the first time are slim, but it'll be a good learning and bonding experience. Charlie
  • 219 Answers
Either that or the piston rings, I would think. Do NOT try to crank it by hand, if it is the rings or crankshaft you will do a lot of damage.
Posted on Jun 24, 2017
  • 1263 Answers
SOURCE: 2001 mitsubishi eclipse spyder gt 3.0L V6 sputtering
if they refuse you do have grounds for a small claims court. as far as piston rings are concerned it is always wise to replace them all instead of just the bad one. in order to do this you have to take the head off any way so might as well just go ahead an replace the rings. drop in motors come from salvage yards, most of the time it's from vehicls that were either wrecked from accidents stolen and damaged beyond repair. in these vehicles the motors are sti9ll good. generally depending on what the motor is the cost can be 250- 1000 and labor is about 500-1000 this will save you quite a bit of money usually . the downside is you only get a 30 day guarenttee. rebuilt engines from the manufacture can be 1500- to 3000 have a 3 year 50000 mile warrenty but they are called long blocks just the block and heads. all your accessories like altenator,water pump, etc have to be put back on. the best way to do this is find some you can trust and have them go with you to find what you need to get the job done. i'm sure there is alot of deals out there that will save you money and good mechanics that can get your vehicle running the way it should without ripping you off. I'm in iowa and i run across this type of problem all the time. hope i have been helpful. good luck and keep me posted. please rate this solution.
Posted on Aug 29, 2008
  • 52 Answers
SOURCE: engine won't keep running
if it runs on starting fluid then stalls then its not getting gas. try cleaning all of the carb jets.
Posted on Jun 11, 2009
  • 3433 Answers
SOURCE: kick start has no compression but runs fine once i get it going
Does it feel like yhe kick is even engaging and turning the crankshaft? Are you full stroking/kicking it over or short stroking it? when cold, are you using the choke. I suggest taking a compression test when it feels as if it hs no compression It could be undersized piston, rings, or a simple. good luck
Posted on Jun 12, 2009
SOURCE: Need rebuild kits for carbs for a 1982 Goldwing Aspencade
Posted on Aug 12, 2009
  • 4669 Answers
SOURCE: 89 wrangler 2.5 5 speed.replaced crank sensor last
It sounds like your new crank sensor is defective. It should be under warranty.
Posted on Sep 02, 2009
Can I rebuild my enging in a kasawaki Prairie 400 4X4 year 2000
With all due respect to your enthusiasm, if you have little engine or mechanical experience you do not want to try rebuilding an engine.
With transmission it can weigh 1000 pounds
If you have an acquaintance/friend who is experienced suggest you do a rebuild together. No disrespect intended, a rebuild can be a technically demanding task
Jun 12, 2015 | ATVs
150cc Kazuma Dingo ATV
buy new one online
Jul 29, 2017 | Heavy Machinery
Starter replacement
I passed this question up yesterday because people don't generally rebuild starters anymore. They exchange their starter for a rebuilt one at a parts store. I suppose you can still buy the brushes and the bushings to do it, but I haven't in 25+ years.
Aug 21, 2012 | 1998 Oldsmobile 88
My son's weedeater Model# MX550 doesn"t have a manual and he needs one to be able to rebuild or clean the carburator, as he left gasoline in it over last winter.
This is as easy as 1, 2, 3.
1. The weedeater manual for this machine will not tell him how to clean and rebuild a carburetor.
2. There are good videos on youtube for clean and rebuild of two cycle carburetors.
3. Using the brand and model number you will be able to get a carburetor rebuild kit for less than ten dollars I think from a local small engine repair and repair parts shop.
I hope this is helpful for you.
Sep 01, 2011 | Poulan Garden
How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Dec 21, 2009 | Toro Garden
1992 eagle talon white smoke
check for pcv valve and vent for blockage ,should be vacuum. valve train could be stopped up and not draining down ,or u need a ring job rebuild
Jun 27, 2009 | 1992 Eagle Talon
95 Eagle talon tsi FWD won't go into 5th
Most likely your synchros or too much grind and find. Just do a good ol' fasion rebuild and take care of any other potential problems that could pop up in the future. Good luck
May 17, 2009 | 1995 Eagle Talon
Electronics - Others Logo
1,726 people viewed this question
Top Talon Electronics - Others Experts
Are you a Talon Electronics - Other Expert? Answer questions, earn points and help others
