Question about Nikonos V 35mm Point and Shoot Camera
I can't advance the film of my Nikonos V
After instaling the new film, I could advance two frames with the lid opened; then I closed the lid and kind of the lever stuck and couldnĀ“t advance the film anymore, of course it is ffixed in "A" and I have tried in "M","B",etc. It happened after a week of using it UW and of course no water in and a thorough sink washing rigth away when leaving the boat. I opened the lid and took the film out an tried once more and nothing moved.
I had the camera serviced two days before my diving but, it was made in the diving resort. Away from home.
dll932
  • 40 Answers
SOURCE: help, my camera wont take pictures
Did you try pushing the shutter button? It may already be wound. Otherwise, try pushing the rewind button in and holding it while you wind the lever. Now, it MAY be that your at the end of the roll-what does your counter say?
Posted on Jun 11, 2007
cammedic
  • 667 Answers
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Posted on Apr 27, 2008
  • 44 Answers
SOURCE: film advance lever
please read the manual... u ll get the solution.
Posted on Jun 24, 2008
SOURCE: Shutter won't depress, advance lever won't move.
how? i have the issue too.
Posted on Sep 08, 2008
Obertelli
  • 3006 Answers
SOURCE: film is stuck in kodak advantix
APS cameras are very rarely seen these days because the film loading and advance mechanism was poorly designed and engineered from the start.
Your fault is very common and given that the camera will be irreparable anyway (no spares, plus the small problem that the camera was never designed to be repaired anyway) then you need to decide whether to just chuck it away or whether to break open the camera in total darkness and manually rewind the film back into the cassette for developing.
Posted on May 15, 2010
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Film advance lever stuck. Changed batteries but can not move the film advance lever.
Hi fmerlin, If you have film in it you may need to remove the film to free up the advance lever. Go into a closet cover under a blanket etc. Also, Walmart and most drug stores have a big change bag that they could do it for you. With film out it still will not advance it will need to go to Nikon.
Aug 18, 2010 | Nikonos V 35mm Point and Shoot Camera
Mamiya 645 AF back won't advance film.
The battery in the film back is only used to supply power when the back is off the camera, when it is on the body power is supplied by the six batteries in the body so try them and also make sure the film insert is properly seated.
Feb 07, 2010 | Mamiya 645AF Medium Format Camera
Nikonos v with Nikon 15mm f/2.8N UW-Nikkor IC... > for sale
Good lord! That's a NICE underwater system you've got. What type of help are you asking for? Just from your equipment list, if everything is in good condition, you've got at least 1500.00 worth of stuff! A new 15mm sells for $2,240, the camera, new, $750.00, eiklite flash system is up there, the extra close up gear ain't cheap either! And a pelican case--well, if yer gonna go snorkeling or scuba, you're all set! The 28mm can be used for land lubbing or underwater. To properly prepare the camera, the most important thing is to check the condition of the o-ring around the film door. If any doubt, replace it!! The same applies with any other o-ring seal. *Properly* greased, an O-ring in good condition simply looks wet. Use a good quality, pure, silicone grease all over the ring and don't blob it on--It can be purchased just about anywhere. Check the o-rings on all the other equipment--same rule applies. Salt water damage is u-g-l-y. Before opening up the camera after being in salt water, rinse all equipment in fresh water and dry completely. Don't detach any cords or lenses until all are rinsed and dry! (When cameras and salt water come together improperly, think horror movie acid bath results--and you won't be far off) I used 36-picture rolls of film so I wouldn't have to open the cam as much. Heh, in the excitement of photoing fish, yer gonna burn some film.Hope I assisted you!---Rick
Oct 02, 2009 | Nikon 15mm f/2.8N UW-Nikkor IC Lens
I'm wondering what kind of batteries a Nikonos 111 takes. thanks
I found a friend who had the same camera, and he informed me that the camera doesn't use batteries. That space is for a flash unit.
May 12, 2009 | Nikonos V 35mm Point and Shoot Camera
Nikonos V underwater camera w/ strobe
It sounds like you'll need professional service. Even slight moisture damage can foul up the shutter or the wiring that runs from the camera to the inside of the connection port. You can remove the access plate (4 screws) above the film chamber. The 5 wires below the rewind knob (blue,yellow,purple,green,black) lead to that connector. I would also check the shutter functions on M90. See if it opens.
Sep 30, 2008 | Nikonos V 35mm Point and Shoot Camera
Nikonos v
One thing that can happen with the V is that the oring on the release lever gets dry. This can cause the release to stick in the down position. If it was in the down position and you tried to advance the wind arm, it may be jammed internally. The only way to fix this problem requires dis-assembly of the camera. There are sites with info on this or I can help you here. If this might not be the problem, try releasing the shutter in the M90 mode.
Jun 29, 2008 | Nikonos V 35mm Point and Shoot Camera
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Light meter does not turn on
The frame counter must be at '1' for the meter to work on this camera
Dec 13, 2007 | Nikonos V 35mm Point and Shoot Camera
Nikonos V 35mm Point and Shoot Camera Logo
223 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
