Question about KitchenAid KAWS850L Top Load Washer
KitchenAid Superba Selectra tub overflow and cycle dial logic off
KitchenAid Suberba Selectra (10 cycle, 2 wash, 3 spin speeds) -- about 12 years old.
One day (and since) it overflowed upon regular fill (any cycle; wash or rinse). At the same time (likely not by coincidence), the cycle dial settings became corrupted. The fill, spin and drain can be activated in each of the cycle modes, but the agitate can only be initiated at one spot on the dial (normal wash; about 2 min before drain). The fill is now stopped by pulling and resetting the dial. The wash (agitation) can only be prolonged by resetting the dial to the single trigger spot. The dial does move as a timer during the cycle.
We just recently replaced the motor (about 1 month ago), so I hesitate to ditch the machine. Could it be a switch or circuit board problem at the cycle dial level, or is this a motor/dial logic problem resident at the new motor? We noticed that prior to this happening, and on small loads, the machine moved around a quite lot on the floor. Possibly the motor was overworking. Possibly something that was shook to no longer functions.
Please advise.
  • 409 Answers
SOURCE: Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
Posted on Sep 28, 2008
  • 85 Answers
SOURCE: KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Posted on Dec 21, 2008
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
  • 74 Answers
SOURCE: kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Posted on Oct 03, 2009
  • 464 Answers
SOURCE: Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Posted on Oct 04, 2009
Kitchenaid Superba dishwasher getting louder in wash cycle
The bearings in the wash motor can wear and cause the machine to get louder, They can be replaced but it depends on the age of the machine if it's worth repairing or not.
Mar 08, 2012 | KitchenAid Dishwashers
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Oil is spewing into the wash tub during the spin
This may be a busted tub seal, but is usually caused by the outer plastic tub retaining grease and debris from previous loads. I would try running a hot water only wash cycle at full water capacity and adding a strong degreaser. This should emulsify any left over grease while also washing out the outer tub. If the problem persists, you may need to repeat the procedure. Remember that your washing machine transmission is located below the drum and tub assembly and is full of oil, but that oil simply cannot travel uphill.
Mar 13, 2010 | KitchenAid Superba Architect KSCS25INSS...
Very loud on high speed spin cycle Sounds like jet turbine Frigidaire Model FWSB67RGS0 almost 10 years old. Was given to me. Don't know if it has always been this loud.
Most likely the tub seal on the bottom is starting to leak water onto the bearing under the tub and now the bearing is starting to go bad.
Jan 01, 2010 | Washing Machines
My Kitchenaid Superba washing machine won't advance to the next cycle. For instance, it will stay on the wash cycle until you push the dial in and manually move it forward to the next cycle.
ck ing the model # it doesn't work but a washer that the timer will not adv . its just a timer failure . replace timer as it is bad .. you will need a correct mod # of the unit to pur timer .. hope this will help **** ..
Dec 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Spin cycle not working like it should
If the washer doesn't reach it's proper spin speed, the clothes may be wet at the end of the cycle. Since you have replaced the belt, it could be that you have a worn motor pulley or tub bearing. Check for damage to the pulley and shaft and for free play. Also make sure that there are no clothes or foreign objects caught between the inner and outer tubs or something causing friction on the drive train. Hope this helped.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
179 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
