Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
After my MBP has been running for an indeterminate period of time, every 10 seconds or so, I hear a single beep from my speakers...whatever sound I've chosen for my alert. When I try to open new apps, I get an error (-10810)...restarting solves the problem temporarily. What does -10810 mean?
  • rann956 Sep 25, 2009
    I'm running 10.5.8. I do have Virex installed, but notice it will no longer launch...something about can't find engine.
    Scholar:
  • 131 Answers
Here are a couple suggestions:
1. If you're using 10.3, you need to get rid of the following:
/Library/Caches/com.apple.LaunchServices.6B.csstore
~/Library/Preferences/com.apple.LaunchServices.plist
(where '~' means your Home directory, i.e. '/Users/yourname')
2. If you have Virex or other virus software installed, try uninstalling it. Be sure to use uninstallers that come with the software because simply deleting the application does not fully uninstall most virus software.
Be sure to shut down for a couple of minutes, then do a restart after the above.
I have read that the 10.4.7 update will require a patch that includes missing pieces for intels. If you cannot load terminal to check processes, rebooting is the only cure so far. If you can load terminal then try this:
Check to see how many processes you have running, some people have reported over 500!! Thats crazy! if yours is hi try running this as a test "sudo killall -9 smbd" That should clear your processes up quite a bit. I also read that printer sharing can do this sometimes. This is a problem with the Intel chips and MacOSx from what I have read. The system for some reason doesn't release the processes once it is completed with them. I hear that they are working for an update to rectify this problem.
Hope this helps
Posted on Sep 25, 2009
PS3 will not turn on. Red Light and a single beep only.
It appears that this PS3 has the infamous "yellow light of death". This is common among older PS3s, that have overheated. It can be fixed by Sony, for about half the cost of a new one plus shipping. Keep in mind it will not have a warranty on the fix. You can attempt to fix it yourself, if you have the proper tools, patience and level of skill. Difficulty on a scale of 1 to 10, 10 being the most difficult, about an 8.
Apr 12, 2014 | Sony Playstation 3 (PS3) Console
Acomdata external hard drive not opening MBP
Acomdata Drive Not Recognized: I ran into the same issue. Actually the issue was with using an incorrect power adapter. It should be with power ratings of: Input 50-60 Hz 1.2A & Output 5V - 2A, 12V - 1.2A
Jun 22, 2012 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
Cobra 29ltd bluetooth,bluetooth stuck
To disable the Bluetooth link
Press and HOLD the Bluetooth button on the microphone until you hear a double-beep. You
may hear 1 or 2 single beeps, just keep holding the button until you hear a double-beep. The
Bluetooth light on the CB should remain dark.
To re-enable the Bluetooth link
Press and HOLD the Bluetooth button on the microphone until you hear a single beep. The
Bluetooth light on the CB should blink every 10 seconds.
Sep 25, 2011 | Cobra 29 LTD CB Radio
I have the rona keyless entry lock (with single numbers on the front to enter our code.) For some reason, I cannot get it to change the code and have since lost my instructions. Can you please tell me...
remove all batteries then press any button on the keypad 3 times.Wait 10 seconds then replace batteries.You should hear a long beep followed by a short beep then press and hold the 0 button for 3 seconds. Red LED should flash 3 times and you should hear 3 long beeps. Now release the 0 button. Now enter new Master code (4-12 digits) followed by the LOCK button.You only have 15 secs to do this. LED should flash green once followed by a melody tone. Good luck
Bob...
Sep 07, 2010 | Directed Dei Valet 561r Remote...
Sounds like my computer underwater
Try to update the Itunes and Mac OS X.this can solv the issue
Mar 09, 2010 | Apple MacBook Pro Notebook
No picture, no sound, single intermittent beep
I suspect your flyback transformer is bad. Get a service manual and let me know when you have it to meail me and I can pinpoint the exact issue most likely.
Oct 29, 2009 | RCA TruFlat 27F520T 27" TV
No menue just background when turned on
9 times out of 10 this is a hard drive issue. You can try removing it and reinstall. If your lucky! this will fix But most of the time you will need to do the following
1. remove all cd's,memory or anything you have connected to the ps3 on the usb's
2. turn on your ps3 from the back switch but leave it with the red light on(on the front).
3 now press the power button (where the red light is)and hold it, you will heard the initial single beep then you will hear a second single beep after that you will hear a double beep. when you hear the double beep release. You may have to do this twice cause it doesn't always work the first time
4. a menu with 6 option will appear. 1st rebulid file system and restart
If that doesn't work then try system update
Note: You'll need a flash drive with Playstations 3.01 update
Here are the instruction on how to do system update with flash drive
http://www.us.playstation.com/Support/SystemUpdates/PS3/PC_Update.html
if that doesn't work you'll need to restore PS3, note this will delete all your data
Good Luck
Oct 23, 2009 | Sony Playstation 3 (PS3) Console
Annoying beeping of the Kenmore refrigerator!!!
I don't believe this model has an alarm in it. The beep you hear maybe the evaporator fan motor, also if there is an icemaker in the frig be sure it is turned off
Jan 24, 2009 | Whirlpool ET1FHTXM Top Freezer...
No sound driver
Turn the power off. Wait about 10 seconds,then power up again get close to the reciever and listen for a click-not from the speakers ,fromthe recievers itself.If you hear a click,you can assume that the power supply is ok for that cercuit.This does'nt eliminate the power supply,but it will do for now.Put the speakers close to the reciever,what you will do now is to power up the reciever while listening to the speakers with the volume off.In about 3-5 seconds you should a hear a slight click from the speakers. Try this with both speakers if you don't plug in a pair of headphones to the headphone jack and play the source . If you still no sound with headphones you at least now know that the output transistors are not the problem or the only problem.The power amp., section are defected also.Message whatever happens.
Jun 17, 2008 | Audio Players & Recorders
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
47 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
