Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code h-f
Washer will start regularly then cut off and alarm. the display blinks "h" and then "f". I have done what the troubleshooting in the manual said and tried again it does the same thing. then i unplugged it for about twenty minutes and re-started with an "empty" express wash. it did the same thing again. ??What is this error code and what can i do to fix it??
  • 2 more comments
  • Anonymous Dec 19, 2007
    washer stops and will not drain error code sud
  • Anonymous Feb 05, 2008
    I also have been getting this error code and can't seam to fix the problem
  • Cujocoka May 04, 2008
    I have the same problem. It just keeps showing the error code no matter what I do, even when I stop it and use the spin and drain option. We have also tried unplugging it and re leveling the machine. I can hear water draining out of it but it still flashes F 02.
  • Choo Choo 1 Oct 24, 2008
    i Have the same problem but the water goes in and out of the machine.the diagnostic test runs C00-C03 and then shows a FH code. I switched the hot and cold water valves and it has made no difference. Please I need some help.
    Thanks
    Problem Solver:
  • 16 Answers
Krysil,
I have the service technician's guide to the error codes here. The code you're getting is F/H. The Explanation of this error code is "No Water Detected Entering Machine or Pressure Switch Trip Not Detected."
"If after 30 seconds, the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash."
"Possible Causes / Procedure
  • If there is no water in the unit:
    - Make sure that both valves at the water source are turned on all the way.
    - Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
    - Verify inlet valve operation.
  • If there IS water in the unit:
    - verify drain pump operation
    - verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
  1. Verify that there is not a siphon problem.
  2. Unplug the washer or disconnect power.
  3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter, and Central Control Unit (CCU)
  4. Check all hoses for possible leaks.
  5. Plug in washer or reconnect power.
  6. Verify pressure switch operation.
  7. Verify flow meter operation by blowing air through the part and measuring the resistance.
  8. Verify CCU operation by running a Diagnostic test or any cycle.
Whew! Well, that's what the service tech manual said. Hope that helps! By the way, I found this service tech manual behind the lower front panel of my washer, attached to the right side of the frame. Yours might be in there too!
Posted on Feb 28, 2008
I get kenmore washer lcd panel option had been dead,has been using 8 year so far,now it just do a basic wash 20 mins total but not aging,fill wafer then little agging stop for while then drain,clothers did not dry enough,pcb control panel cost about $200 bucks,labor for tech add another more.Could any best solutions for me... thanks
Posted on May 15, 2008
I only get this error code at the beginning of the Rinse cycle.
My low-tech solution (after not finding any problems as listed above) is to end the wash cycle, punch in the Rinse/Drain cycle and Start.
Posted on May 01, 2008
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
F- code does not show code in book what and how to remedy the problem?
Hello there again here is some more info for you
Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is error code 6500?
This is an error indicating a problem with the Logic Board Assembly. It's probably not worth fixing, with printer prices being fairly low.\
According to the MP800 Service Manual:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (COPY button), or
Alarm LED Lit in Orange)
Service call errors are indicated by the number of cycles the Alarm LED and COPY button blink, and the corresponding error
code is displayed on the LCD.
*Cycles of blinking in orange (Alarm LED) and green (COPY button) - 20 times
*Other hardware error - Error
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
Aug 21, 2010 | Canon MP830 All-In-One Printer
Lid switch need to replace switch or fuse, is the whole switch in the lid ???
Hey fireball1711 I'm at work on lunch break I give you a few some info to get ya started. The Left Lid Lock has big time problems with corrosion issues with it?s proximity to the bleach dispenser. Are you throwing an "OP" or ?OD? error when you hit the start button? Take a look at these links below to get you started. You will find a replacement part number for the Left Hand Lid lock the Service Manual and a parts look up links. The common console errors that stop the washer from working are ?OP? & ?OD? caused by an open lead on the magnetic reed relay, lid magnet out of position and corrosion on the male pins and plug assembly. The last alarm is the ?FL? error code for failed to lock again corrosion issues produce these faults most of the time. Don?t worry about the Right Hand Lid lock. I would disconnect it?s plug, tape of the plug end. It simplifies troubleshooting. You only need Left Hand Lid lock to operate for the washer to work as designed. If you can give me the details on the Console error codes you display that will help. Try the tips I mention in the links below and post back with any questions. I can dedicate more time to your issue after work tonight. OD Alarm OP Alarm Good Luck??. Rich
Oct 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
184 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
