Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Scanner error 5
It started about a week ago when I tried a print. At first, all the display would be was the chevrons << << . I tried turning it off and on with different results. Sometimes I would get the chevrons, sometimes two and sometimes 4 and sometimes no display at all. Now all I get is "scanner error 5"
Thanks
  • 375 Answers
This error normally comes when the Step Motor is Defective. It needs to be repaired. It is a Part associated with the Scanner Assembly. But before going for repair, try to re-install the Driver and the whole software of the printer. This may also solve the problem.
Thank you Sir, Have a nice day.
Posted on Sep 25, 2009
How can solve in this problem
Dear
Go to TECH mode, doing......(pressing the following keys in serial within 3 secs.)
MENU,copies,<,>,menu,>.
next place a white A4 size paper on platen glass.press MENU scroll to display TESTING press OK, scroll to display SHADING ADJUST press OK . a print out will come.
This will display the status of CIS. if RESULT is OK in the print, Printed at bottom of the page, the printer may work but prepare for the scanner cable (black ribbon type,visible under the platen glass has to be replaced).
Thanks.
Feb 02, 2015 | Samsung SCX-4300 Monochrome Laser...
I have a fax-jx200 it shows ;auto print off . so there are faxes in memery how do i get to turn off auto print.
Press [ON/OFF] to select <auto print off>
The fax starts receiving documents to the memory
To cancel press [ON/OFF] again.
Oct 20, 2011 | Canon FAX-JX200
At certain periods in time all my pc browsers begin to display a web address that i did not type the address is http/***.yyy.zz i have a hp 625 laptop and my catalyst control center does not start it...
You may have a virus. Scan the PC with a reliable antivirus. If you are unable to download one, get a friend to download one that can be run from a USB stick
Oct 18, 2017 | HEWLETT-PACKARD 625 Tur II P540 Notebook
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit &lt;Enter&gt;? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
The message prints out from my HP Officejet 7410: A communication error occurred during the transmission. Result Error 232* It was working fine before, now it won't fax 2 pages.
Actually Error 232 is mostly because of the Remote machine still we can try one thing in your machine ie - we can disable Error correction mode
How to disable it?
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
Try to send fax now .. It should work
Please Vote for me if it works
Jan 04, 2011 | HP OfficeJet 7410 All-In-One InkJet...
I have a mutoh toucan lt i have 3 problems with it 1, i just replaced a print heda and need ot know hwo to set the individual voltage for it. 2. the language keeps getting reset to japanese. i...
Mutoh Toucan LT error E105 fuse 4 error
This Machine is 5 year old ,the problem start with System error E111 Head over heat 2,I replace the ribbon on Cyan was printing OK on small size job,wen I try to print a large size panel the machine will stop and display error E11 Head over heat 2 .
Were is the fuse 4 on this older model?
If the fuse went, is have a problem in the printer head?
PLEASE HELP
Ralph
May 29, 2010 | Office Equipment & Supplies
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Lexmark 2500 won't print but no error message
Yes,I unplugged the printer for several hours.  I also tried another printer and it would do the same thing.  No error message but would not print.
Oct 13, 2008 | Lexmark All-in-One Printer with PictBridge
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
401 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
