Question about LG KU990 Viewty
Dropped into water not working - LG KU990 Viewty
    Problem Solver:
  • 5 Answers
You need to buy another phone the led light went out because u dropped it n the water
Posted on Sep 25, 2009
I dropped my garage door opener in dog water bowl. now it won't work. I replaced the battery but still won't work.
It has to dry out....Put it into a bag of rice and leave it there. It will eventually draw the water out...That's what they do to cell phones dropped in water.
Feb 28, 2018 | Building Materials
Tip
How to unclog a clogged print head on the Canon...
Using a cotton swap dip into some plain water and then drop a few drops of water onto the outlet of the ink cartridge [you will have to remove the ink cartridge and turn it upside down].
Also while the ink cartridge is still removed, drop a few drops of water onto the inlet orifice into which the ink goes. The orifice of the ink cartridge sits right on top of the inlet to the print head when the ink cartridge is fully installed.
After putting the water drops onto the ink cartridge and onto the inlet orifice of the print head, I did the 'clean' procedure as listed in the "Canon PIXMA iP4000 Properties" of the program on my PC. Then I did the deep clean procedure. After that I printed the print pattern and found that this technique worked quite well -- since before I had tried isopropyl alcohol which didn't work to unclogged these print heads.
When I had the blue print head get clogged [on my Canon iP4000 Pixma printer] and I tried this method. It worked immediately.
I hope it works for you too.
God be with you!
engineer550.
on Jun 16, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Pressure gauge drops to zero when hot tap turned on
There are multiple types of systems that use the configuration you are talking about. We have no way of knowing what the system is but there is obviously a supply problem. Either the pump is not working correctly or the water supply has been constricted.
Jan 10, 2016 | Water Water Heaters
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
By mistake i dropped my nokia c3 in water and the keypad doesnt work now
Usually when the mobile falls into the water you need to remove everything and immediately take it to a service center so that they will wipe it with some petrol. Now it doesnt work since you dropped it in water only. Check it again with a Nokia service provider.
May 26, 2012 | Nokia C3 Cell Phone
I dropped my phone and it could not on now
Due to hazard some phones are not working. If you dropped in water try with this steps.
  • Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately.
  • If the phone will turn on, you can try to make a call to be sure it is working properly. If you put your water damaged cell phone back together and it won't turn on, it is likely that some water has gotten down inside the phone.
If dropped in floor, please bring it to service center for repair.
Jan 04, 2011 | Cell Phones
I dropped my player in water. will it work again.
sorry.... It might not work properly.... kindly rate me... thank you...
Jun 30, 2009 | Sony NWZ-S718FBNC 8 GB Walkman® Digital...
Samsung F480 dropped in water
have the phone check at a repair center and have them test the camera the problem sould be from the board.
Jun 06, 2009 | Samsung SGH-F400 Cellular Phone
Dropped in water
I posted a fix some time ago that might be relevant to your problem - http://www.fixya.com/problems-solutions/t102703,p401560/Nokia-6230.aspx Hope you work it out ;]
May 02, 2006 | Sony Ericsson K750
LG KU990 Viewty Logo
74 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
