Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
LCD screen doesn't work - Olympus Camedia C-8080 Wide Zoom Digital Camera
How to replace a cracked screen
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Nov 06, 2012 | Computers & Internet
Lcd replace
You should the installation instructions with the new lcd screen
Hope this helps
watch video
Nov 04, 2012 | Computers & Internet
All white screen
tried to replace the vga cable and fix the vga port doesn't work?.if still white screen the cause will be bad lcd controller.
Oct 27, 2012 | LG Flatron L1710S 17" LCD Monitor
Screen is non-functional and irreparable
hope this helps
Sep 17, 2012 | Computers & Internet
My phone is already white screen.nokia N80
White screen are symptoms for Contact retailer. try to call 112 (emergency call) if its working, meaning it's LCD problem. If 112 working try to clean the terminal of LCD. IF this doesn't work consider replacing it.
Sep 09, 2011 | Nokia N80 Cellular Phone
My dell latitude d800 dosnt start. no cursor no splash screen ..only lightning some buttons..
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Sep 03, 2011 | Dell Latitude D800 Notebook
The display system of the vaio notebook went dim then finally died out.what is the possible problem and solution to the same
Hi akeyow..
Sounds like you have either a bad lcd screen or a bad lcd inverter.
To check to see if the screen is bad, connect the notebook to an external monitor that you know is working...if it works the you will have to replace the lcd screen.
If it doesn't work then the internal lcd inverter, will need replacement.
Both replacements take a better than average skill to replace, maybe best left to the pros...or sometimes you can check out YouTube and some people show you how to do it.
Please take time to rate me
Sony lcd replacement:
http://www.screentekinc.com/Sony_Vaio_VGN-CS_Series_VGN-CS215J~W--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is a link to the YouTube webpage for replacement, could not find your model, but I am sure you could use some of the info to replace what you have...
http://www.youtube.com/results?search_query=Sony+VAIO+VGN-CS215J%2FW+screen+replacement&aq=f
Lcd replacement, lcd inverter replacement
Aug 22, 2011 | Sony VAIO VGN-CS215J/W Notebook
Screen occasionally develops white horizontal lines starting at l&r of screen then fills screen adjusting angle of screen or a very light tap brings screen back to normal
Hi, Unfortunately this usually is a premature sign of the screen going bad. If you still have warranty on this, I'd suggest you take advantage of it. If you are technically inclined and understand how to open the laptop, you can try cleaning out the slide where the lcd ribbon meets the motherboard. Or on some laptops you can swap out the cable itself. My dog **** on my hp once and I started getting lines, I had to replace the ribbon. If this doesn't work, then its the lcd screen itself. So all in all, if you have the warranty...use it. If not, change the cheaper part first which is the ribbon. And if that doesn't work, swap out the lcd which usually you can buy online. Buy new ONLY for lcd replacements. I got mine from ebay. I used to do this type of work for a living and this is the best advice I can give you through a typed communication. I learned that when opening up any complicated electronics, take your time, take your time, take your time. Most people start accidently breaking things when they get aggravated and impatient. =) Hope this helped.
Jan 18, 2011 | HP SMART BUY 2530P SL9400 186G 2GB 250GB...
Replace LCD screen on Kodak m853 camera
KODAK doesn't sell spare parts. An OoW repair for this fault is 48,44 pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 09, 2008 | Kodak Cameras
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
29 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
