How do I adjust the sync roller? My copies are
How do I adjust the sync roller? My copies are being pushed off the page.
  • 257 Answers
Clean the registation clutch, then the roller with damp cloth either with water or alcohol. If no change use command 50 sub 01 and adjust the copy lead edge.
Posted on Sep 25, 2009
Copies have ink smudges at top of all pages. Canon Imagrunner 2000 model. It seems that the toner is showing up on each copy.
this is problem with fixing nip - pressure between fixing roller and silicon pressure roller.
To fix this you need to change the fixing roller, bushing of fixing roller and maybe silicon roller.
Call service!
Hope that helps!
Sep 02, 2011 | Canon imageRUNNER 2000 Copier
Displacement for colour copy horizontal with the itb belt, I am sorry I do not have a credit card
Additional Function key>adjustments and cleaning>auto gradation>choose quick adjust first > then do full adjust.Should print 3 pages follow instructions on screen. If this does not do it the ITB needs to be taken apart and the rubber rollers cleaned. DO NOT CLEAN the foam rollers there should be 4 foam rollers at the top don't even touch them as they will be damaged. Simple Green or 409 degreaser should work fine to clean them. Try not to touch the ITB or kink or wrinkle it during disassembly.
Jun 30, 2011 | Canon imageRUNNER C3200 Copier
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jan 14, 2011 | ESQ 07301132 Aerodyne watch
How do I change the sanding belt on my 7447 belt sander
To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
Canon ir5000 copies have horizonal bands of light copy quality. How do I get even, good quality down the entire page?
The machine probably needs a service paying attention to the development and the cleaning areas. Also, clean or replace the corona wires and check that there is no flat spots on the fuser roller.
Jun 18, 2010 | Canon Office Equipment & Supplies
We have tickets with four copies and the last copy you can hardly read
There should be a small ratchet lever to the side of the printer which adjusts how close to the roller the printhead sits. If you adjust this in a notch or two it should move it closer so that it strikes the paper a bit harder. If you move it too far it will smear the top page so try it 1 notch at a time.
Apr 28, 2010 | OKI MICROLINE 320 Matrix Printer
Duplex doesn't push the paper high enough to finish the second page so it stops the copier ... paper jam.
try cleaning your duplex feed rollers maybe it would help push tru your second page for complition of your duplex copy
Dec 19, 2009 | Canon NP 6035 Copier
My Rocoh FT 4220 leaves a blank strip across every page that I try to copy. I have cleaned everything I could, but must have missed something. The blank strip is not always in the same location on the...
Clean the optical section(glass,mirrors,lems)Verify the paper dust on the edge of the cleaning blade,if the OPC drun scratched or the fusing hot roller scratched.Press the cleaning blade release lever down several times.Make a copy and stop the machine when the paper reaches the transport section.If the lines appear replace the OPC drum.After replacing the drum perform the Drun initial setting,Light Intensuty Adjusment,ADS voltage adjustment,Vsg adjustment.
Sep 25, 2009 | Ricoh FT3713 Copier
Missing pages
Your Doc feed needs new Rollers and Seperation Sheet/Pad, it is pulling pages, but not all the way, while the scanner continues to scan. the ADF might also need adjustment.
Jun 11, 2008 | Sharp AR-M237 Copier
Brush roller lines in feed direction of pages
Maybe the charge roller. Make sure it is very clean. You can also stop a copy before it enters the fuser to rule the fuser rollers out.
Feb 08, 2008 | Panasonic Workio DP-2330 Printer
27 people viewed this question
k24674
jasbo
jasbo
