I have a Savin 2513f machine. The replace toner light came on the other day and I replaced toner. It worked fine for 2 days then the replace toner light came back on. the cartridge is half empty now. It won't print or do anything now. It will cycle through like it's sucking out powder from the toner but the light comes back on.
    Brigadier General:
  • 3,614 Answers
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Posted on Sep 25, 2009
I replaced the tone cartridge in my Savin 2400WD copier, but the light still indicates that I need to change the toner cartridge. What do I do?
I hate to say it but switching it off at the wall waiting a minute and then back on sometimes resets its little brain.
I trust the toner cartridge is all correct for this model.
May 13, 2015 | Savin Office Equipment & Supplies
LIGHT COPIES WITH A NEW TONER CARTRIAGE
Was the toner sign on when u replace the toner bottle?
Dec 02, 2013 | Savin Compatible Copier Toner Black For...
Trying to replace toner in a savin 9922dp. install the toner cartridge, copier runs like it is loading the toner but then the error message to replace toner appears again (over and over)
take the toner out - whilst the green handle is up (this will get your hands dirty) feel inside for a left over cap from a previous toner. remove it and put your new toner in. this should sort it
Oct 02, 2013 | Savin 9922DP Toner 6 Ctgs/Ctn 66000 Yield...
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
Savin 2513F, prints PDF files intermittently
I'd try a different driver, if your using RPCS, change to PCL5. You may have to upgrade the firmware in the copier too.
Aug 26, 2009 | Office Equipment & Supplies
Error code
It's fusing web end error code. The fusing assembly needs service work done on it.
May 05, 2009 | Office Equipment & Supplies
Printer installation
try visiting www.ricoh.com for the driver info
Jun 13, 2008 | Office Equipment & Supplies
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
k24674
