Question about Microsoft Windows Mobile 2003 for Pocket PC
Lost all information on Pocket PC iPAQ 2003. It needs to be charged often. Is there also an internal battery that I need to replace? After it went out is asked me to "tap" screen and then I looked and all my info is gone. No contacts & no notes. I am sick cause my daughter's heartbeat was recorded on there. How can I retrieve all my missing info. I didn't ever hook up to my computer. Your help is appreciated.
  • 69 Answers
Sorry, but i think you lost all your info,unless you put it on a s.d. card. yes it does have an internal battery that's probably the cause of the power drain and the lost info. internal battery replacement can be done at most electronic shops. had you a sync folder on a computer you would have a backup. for your daughter's heartbeat the hospital may still have the records. hope this helps.
Posted on Jan 17, 2010
Internal battery charger
Yes you can buy them on e-bay here is the link for one
http://www.ebay.com.au/itm/Charger-For-HP-iPAQ-hx2100-hx2400-hx2490-hx2750-364401-001-367205-001-/360527673086?pt=AU_MobilePhoneAccessories&hash=item53f11fb6fe just charge up the battery externally and away you go I bought a second battery so I can have one on charge charging while I am using the one in the IPAQ so no down time
Dec 08, 2013 | HP iPAQ HX2490 Pocket PC
I just found my HP Pocket PC 2003 Pro, it has been MIA since we moved in 05. Unfortunatly I only found the unit itself and the docking station. It was my first and when it was lost I just went back to...
If it has been hiding for 4 years the battery is probably broken. Your should still be able to find a new battery on ebay for it. Or maybe from HP but it will cost a bit more.
Sep 17, 2009 | Microsoft Windows Mobile 2003 for Pocket...
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
http://www.youtube.com/watch?v=cYwc_-ISnsA
Jul 13, 2009 | HP iPAQ HX4700 Pocket PC
Compaq iPAQ H3800 Pocket PC
I had the same problem with my iPAQ H3800. I bought a replacement battery on eBay for £7.49 and now it's fine.
Dec 11, 2008 | Compaq iPAQ H3850 Pocket PC
Sat nav information deleted
I`m sorry no ingles. mi problema es no conecting Microsof
activesync information windows (No se encuentra punto deentrada del procedimiento CeSvcOpenW en la biblioteca de Vinculos dinamicos CEUTL.dll) please solution problem
tenquiu
Mi Naime.Luis Carlos Ibarra Lopez
Maill.- luis_cil59@hotmail.com
Tel.(871)7330269
Aug 23, 2008 | HP iPAQ RX3715 Pocket PC
Mirrored image IPAQ 3650
Could you write down the part number for the old and new screens to check for compatibility?
Regards,
May 24, 2008 | Compaq iPAQ H3650 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
Microsoft Windows Mobile 2003 for Pocket PC Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
