Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher won't start i checked breaker etc.
  • 30 Answers
Try this. If you have a gfi outlet in the area of the dishwasher make sure its reset and working a lot of times the dishwasher line is run on the same line.
Posted on Sep 25, 2009
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
1) TEST some fuse blown +c. breaker trip , reset.
2) Test the outlet wall, and reset the c.breaker house.
3) Test the switch door, if there are defective or open the starting relais will not start the main motor see the schematic.
May 10, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
Fdb956rbc0
Daniel felix, not a lot of info to work with but lets giveit a check list to start with.
1. Is the power connected to the unit?2. Is there a shut off switch to the dishwasher in the sink cabinet?3. Is it in the on position?
4. Check to see if circut breaker is blown.Hope this helpsJoe Connolly
Nov 12, 2011 | Frigidaire Dishwashers
Start won't work.
Thank you for contacting fixya.com.
A check should be made with the volt/ohmmeter to check if voltage is available to the dishwasher wiring. A voltage check is made by setting the volt/ohmmeter on the 150 A/C scale and placing one probe of the volt/ohmmeter on one wire that supplies voltage to the dishwasher. Place the other probe on the remaining wire. The meter should read 110-125 volts. This would indicate that electrical power was available from the circuit breaker panel to the dishwasher terminal box. If there is no voltage at the dishwasher terminal box electrical wires, the problem could be a defective circuit breaker or fuse, house wiring burned or broken from circuit breaker panel to terminal box. If a defective circuit breaker or fuse is suspected, it would be recommended that a qualified electrician perform these repairs.
Please check this links for an in-depth knowledge to troubleshoot your problem:-
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help
http://www.acmehowto.com/howto/appliance/dishwasher/diagnose-dishwasher.php
http://www.partselect.com/dishwasher+dishwasher-wont-work+repair.htm
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm
Please get back to us if you have further query else please accept the suggestion.
Jun 27, 2011 | Dishwashers
Dishwasher will not start after change in electric meter outside. Dishwasher "popped " when it was started Check all circut breakers etc- all fine
if you have 120volts at plug,chk for a breaker inside unit and again voltage inside unit at terms on cord,then if so chk motor for a breaker on the motor,some have built-in breakers,then check door interlock switch for continuity and proper operation, then if electonically controlled check for a fuse and burns on the circuit,you may have suffered a voltage spike,and do it soon,the power supplier may be liable if you can prove he disconnected the neutral and you only had 240volts,this could be a cause also as it becomes a voltage divider circuit w/o the neutral connected
Jul 29, 2009 | Dishwashers
How do i start the dishwasher
Check the circuit breaker or a switch under the sink or the plug under the sink coming from the dishwasher.
http://tclaundryrepair.com/
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
59 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
