Question about Kenmore 219103 Food Processor
When trying to use, the machine turns on but the blade does not turn.
    Problem Solver:
  • 5 Answers
Motor start capacitor has failed.
Posted on Jan 12, 2010
If If the blade won't start turning on it's own, it's probably the start motor capacitator. Mine did the same thing. I found one for $5 at a small electronics store here in Grand Rapids and my boyfriend replaced it himself. Now it works great.
Posted on Jan 07, 2012
MACHINE WON'T TURN ON AFTER BEING USED
I am guessing that something is not seated properly. Make sure the bowl clicks when turned...drops the pin in. Make sure the top is ("clicked in") locked. If you poured something out of the bowl and went to re-use it, make sure the blade is seated properly; make sure there is no food caught under the blade hindering the blade to be seated. Everything must be locked in correctly to operate safely.
Mar 25, 2014 | Cuisinart DLC-10S Pro Classic Food...
I have the 14-Cup Cuisinart Elite Collection Food Processor. Up until recently it was working fine. Recently when using the shredder blade, when I insert food into the feeding tube the blade stops...
If the unit works OK with other attachments and the problem is only with the one cup; then the blade may be loose and spins on the shaft, the connection gear under the bottom is worn or binding up. Debris is stuck around the blade shaft or from heating up the metal parts expanded and bind when turning.
Mar 10, 2014 | Cuisinart Food Processors
My magic bullet wont spin. It makes the noise but does nothing?
Your black plastic blades, which are on the bottom of the black blade attachment, that interlock with the blades on the base of the machine may be worn down. When the bullet is turned on and these are not interlocked properly they rub on each other causing the interlocking part to wear down so it no longer catches to turn the blades. As far as I know the only solution for this is to get a replacement part.
Dec 13, 2009 | As Seen On TV Magic Bullet Food Processor
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
Im not sure how to use the attachments for my moulinex masterchef vitasum food processor and how to use them when your making a cake.
Visit this link and fill in the details:
https://www.2instructions.com/search.php?cmarque=MOULINEX&modele=MASTER%20CHEF%20VITASUN
Basically it should be as simple as putting a disc or if making a cake with most food processors, using the universal steel blade attachment by dropping it into the jug and turning to lock. Some machines only need the blade tool to just be dropped in. Then put the ingredients in, fit the top lid until it locks, put the feeder tube in to minimise leaks/spills and then turn on.
Apr 24, 2009 | Moulinex Food Processors
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Jammed Blade
Had the same problem. The Cuisinart folks said to fill it with hot tap water - not boiling - then turn it on and off. The heat from the water will unstick the bowl. If it doesn't work first time - refill with hot water and try again. Worked like a charm for me.
Nov 28, 2006 | Cuisinart DLC-XP Plus 20 Cups Food...
Kenmore 219103 Food Processor Logo
1,024 people viewed this question
Top Kenmore Food Processors Experts
richie46
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Kenmore Food Processor Expert? Answer questions, earn points and help others
