Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung HLN5065W Light Engine problem or not?
My 3 year old 5065W will not show a picture at all. For a while, when I first turned the set on, sometimes I could hear the light engine trying to start the set up, but it would recycle and I would get no picture. Sometimes I could unplug the set and then plug back in and the problem would go away. This only happened every couple of months. Recently this happened and unplugging did not help. I used a dust blower to blow out the back of the set through the vents and the TV started working, but only for a couple of hours. When I turned it off, it would not start back up. Next, I took the back cover off and tried to clean off all the dust I could find. When I turned the set on, it worked. I watched TV for 2 hours with no problem. I turned the set off and on and it worked fine. But the next day, when I tried to turn it on I could not get a picture again. Now I am stuck. I had a technicial look at it and he said I need to replace the Light Engine which would be over $1500 except they do not make them for this set any longer. Samsung says they still make the components that make up the Light Engine but they would be more than $1500. Of course it is not worth nearly that to fix a 3 year old 50 DLP TV. Plus, I cannot believe it needs a new light engine when it was working intermittently. I believe my unplugging, dusting, cleaning worked because I have loose connection somewhere and must have reconnected it each time I was moving the set around. Where do I go from here? Anybody want to buy a used 5065W that won't work?
    Problem Solver:
  • 8 Answers
Look at my ether post on cleaning out the DMD bord I thank this will fix your problem.
Posted on Jan 02, 2008
2 Suggested Answers
  • 383 Answers
SOURCE: Intermittent problem of no picture
Archive Projection TV Repair Answered Questions QUESTION NO. P710-9: Sony KP-53XBR45 projection TV picture had severe intermittent vertical pincushion symptoms. Pincushion problem stopped and picture now ...
No thank you, Not interested in buying another TV at this time But the above solution should give ya some ideas in what to look for and could help ya and get your tv back on again.
Good Luck, Please dont for get to Vote.Thank you
Posted on Dec 14, 2007
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
Dec 14, 2007 | Samsung HLN5065W 50" Rear Projection...
I have a Samsung DLP HLN-5065W that turns off after about a minute with 3 blinking lights. The picture is on and looks great. It's like something maybe over heats after a minute. Thanks, Rudy....
Lamp , if you have never replaced it!
Mats has them for $99.00 1-800-628-1118
Encompass Parts Distribution has Parts for this Model
and may the free service manual that you can print out online.
They will list PN # /Prices. 1-800-638-3328
I have the same TV as Yours .Had to replace Lamp and Color Wheel on mine.
Oct 14, 2010 | Samsung HLN5065W 50" Rear Projection...
LEDs Blink but TV will still not come on
This appears to be a logic problem, (address missing) in which case you would need to get a schmatic diagram in order to fault find. It could also be a psu problem, excess current, (trip) short, or excess voltage which is preventing the set from turning on, monitored by the logic hence, giving you blinking LED's.
Aug 31, 2009 | Samsung HLN5065W 50" Rear Projection...
Replace Color Wheel
if the problem is the colour wheel there is a slight delay when first turned on.If the colour wheel is at fault it is located right adjacent to the lamp it is pretty easy to change with 2 screws holding it in place.they are about 100 to 150
Mar 11, 2009 | Samsung HLN5065W 50" Rear Projection...
My Samsung HLN5065W started to freeze to a black and white
I have a problem with my HLN 5065W Samsung DLP that 3 other folks have and no solution. After the set is on from 5 minutes to 6 hours, the screen will freeze in black and white, I can turn it off for 5 minutes and it will display a good picture again. Sometimes the screen will just go dark blue, TV has to be cycled on/off to get the display back. This problem is getting worse, started as once a month, now 3-5 times a day. I have a tech background and can read a schematic, HELP.
Mar 01, 2009 | Samsung HLN5065W 50" Rear Projection...
Self focus not working on samsung 5065w 50 inch asking to check factory data
As ima_rm2000 noted, the HLN is manual focus.  There is a focus ring at the base of the lens assembly.  Here is PDF of the focus assembly.  You have to remove the back of the set to access this, and tape/tie the lamp door switch closed so the TV will power up so you can focus it.
Jan 12, 2009 | Samsung HLN5065W 50" Rear Projection...
Diagonal lines through the picture of Samsung DLP set.
Poor solder connections, resolder convergence ICs or you may beed to replace them.
Dec 27, 2008 | Samsung HLN5065W 50" Rear Projection...
Won't power on , just a click and nothing happens
Bad lamp, color wheel or DMD board. Lamp $199, Color Wheel $350 by professional, DMD/light engine $750 by professional
Oct 25, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
463 people viewed this question
Jerry Greenberg
Jerry Greenberg
