Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Not cleaning! plastic forks that run on the two wires broken
    President:
  • 1,489 Answers
These forks aren't needed to operate the machine, as you know.
You can clean the grid wires with compressed air and electrical contact cleaner. But these units are very unreliable, difficult to impossible to repair, and there are no parts nor repair service available. They don't usually run very long. I'd have to say, as soon as it quits working, shop for an alternative ozone-generating air purifier.
Charlie
Posted on Oct 01, 2009
Red light stays on after cleaning
which model, do you hear arcing or snapping sounds when it's running? Check wires that run along the inside front of the cell, loose, sagging or broken wires will cause this.
Oct 02, 2014 | Oreck Air Purifiers
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
Aug 01, 2014 | Oreck XL Professional Air Purifier
I HAVE 2 IONIC BREEZE QUADRA. FIRST HAD PROBLEM WITH 1, NOW THE SECOND ONE HAS SAME PROBLEM. HAVE CLEANED AND DRIED THOROUGHLY THE BARS AND FILTER, AND CLEANED REST OF WIRES WITH BRUSH. WHEN I TURN ON I...
If none of the hi voltage grid wires have broken then check to be sure grid wires are truly cleaned.
If not cleaned in a while like every 2 weeks they will have carbon build on them. And from my experiences with cleaning them is the build looks similar to the color of the wire. Try some qtips dipped in alcohol or cotton balls. The build comes off like flaking metal. Also be very tender with these wires they break fairly easy. When done cleaning turn upside down and back so beads can scrape up and down on wires. Also you do know once clean the parts especially the big collection bars they need to dry for at leased 24 hours before ever powering unit back on. Hope this helps.
Dec 13, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic Breeze GP S1830 - makes a sizzeling noise
Funny you should post this when you did as I just finished reassembling my S1730.
Mine was making very loud noise, arcing violently, smoking slightly and would give a good shock when you touched the plastic covers(yes dirty plastic will conduct electric current).
1. Unplug the unit
2. Take the plastic covers off, front has four screws and back has snap at bottom, both slide up when loose.
3. Wash the plastic covers
4. take the light out and clean it with windex
5. Vacuum the inside, be careful of the two corona wires
6. Find the bead on each corona wire and while turning them slight so the edges scrapes the wire, move them back and forth to scrap the white power off the wires
7. scrape the cone shape plastic that the corona wires runs into, this build up is the primary culprit of the arcing which is the noise you hear. be careful of the corona wires again. I used an exacto knife and gently scraped it, sandpaper has been suggested elsewhere, once done scrapping, wipe down to clean any residue. The top cones are only part accessible, after cleaning mine the noise still persisted but acceptably lower than before. I think if you completely take apart the unit you can clean this cones better.
8. Reassembly is the same is opposite of disassembling.
Hopes this helps you.
Aug 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Cleaning light stays on
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Jan 18, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Quadra - only red light goes on.
In addition to cleaning the plates on the cartridge, also turn the unit upside down then right side up a few times. There are 2 small wires inside the housing, and each has a ceramic ball on it that cleans the wire when the unit is inverted. Also, look through the vents to make sure the wires are not broken. If they are intact, they run in a straight line, almost the entire length of the unit.
If this does not help or the wire is broken, contact The Sharper Image. I believe this unit has a 5 year warranty. When mine failed, they exchanged it for free, even without a receipt.
Jul 12, 2008 | Sharper Image Ionic Breeze GP SI720 Air...
Red light when swith on power button ?
cell is dirty, or you have a broken wire in the cell.
Dec 22, 2007 | Oreck XL® Air Purifier
Clean button
My ionic pro did the same, the red light just wouldnt go out, so I looked down the plate opening, (with unit unplugged), and could see one of the wires was broken. (these are the ones you clean by pulling up that plastic tab). I am currently looking for replacement wires, will post my progress. GregV
Oct 10, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic pro sizzles and crackles when I turn it on. it doesn't crackle constantly but, it like slowly pulses. it crackles for about a second every 4-6 seconds while it is on high, and a little less often...
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jun 17, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
172 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
