Question about HP Pavilion a330n (Refurbished) (RBDM169AR) PC Desktop
What kind of a wireless card do I need for my old but still operating HP Pavilion a330n? I appreciate if I could get the part #. Thank you,
  • 400 Answers
Basically a USB wireless adapter that supports windows XP will work.
Here is one:
http://www.amazon.com/Addlogix-MA-WL-USB-USB-Wireless-Adapter/dp/B000FTYTWQ
Posted on Sep 25, 2009
    Problem Solver:
  • 7 Answers
Just get a new comp. a new card is 60bucks.
The power button on my hp pavilion a330n does not turn on pc
Hi names rui
hmmmm no power have you check if the power supply is working when you press the power botton if not try replacing it.. if you replace it with a new one and still dont power on maybe your motherboard has a problem try going to a service center and ask them to check it out...
Jul 19, 2011 | HP Pavilion a330n (Refurbished)...
I need to replace the Power Supply from my a330n. I took the old one out last week, the new one arrived and I cannot remember (or see) were the 4 Pin plug goes too. I tried start up with out it, computer...
I'd check for pics on Google images on the model of your tower. Generally, the connectors in PC wiring are only meant to fit their proper connector (you don't have to worry about plugging into the wrong female connector, because it just won't fit if it's the wrong connector)
Feb 03, 2018 | HP Pavilion a330n (Refurbished)...
Sir, recently I purchased HP DV4-2112 Laptop, my Network card is not working. Kindly advise me.
Hello...
I got your issue as the network card is not working in the laptop:
Its is advisable to check with a professional but before this try with the following steps
Step 1: Go to Start
Step 2:Click All Programs and choose Accessories
Step 3:Right click on Command Prompt
Step 4: Click run as administrator
Step 5:Type ipconfig/release and when that finishes type ipconfig/renew
If the HP Pavilion ZD8000, ZD7000, ZD9000 wireless card still can’t work, you better check the BIOS setting.
Commonly after install the new operating system the wireless card setting was turned off in the BIOS automatically.
Hope this would help you
With regards
Priya
Sep 06, 2010 | HP Computers & Internet
HP Pavilion Tx1000 not seeing wireless card. I put a new one in since the old one didn't seem to work, and not seeing the new card either.
That's the problem of the controller chip not the wireless itself. Faulty Nvidia chip on the motherboard. You will need to reflow the chip. Take it to the shop or get the DIY guide from www.msbinc.om
Apr 26, 2010 | HP Pavilion tx1000z Notebook
Hp pavilion a330n Internet Explorer won't connect.
check your IP Adress settings are correct for this machine,
Go to start ,then click on run,Type CMD,Then type IPCONFIG/ALL.it will show you a list of all the devices connected to your machine and your local network,
Have you got LAN & WLAN adaptors on board?
this will explain your message,
you will have to set the ip settings on each adaptor
ie LAN 192.168.1.2 and WLAN 192.168.1.3
This wiil help determine which adaptor is to be used when connecting to the network and the internet.
If your using wireless on computer to connect to the internet then run your wizard to help setup the connection
Same for the wired LAN ,use your wizard
The settings for your modem can be reset easily and your ISP will help get you connected to the net because you already have an account with them,
Cheers MISTERDJ
Apr 10, 2010 | HP Pavilion a330n (Refurbished)...
Wireless problem with HP DV6233SE Laptop
try a USB Dongle Wireless, from dlink is very affordable, is external wireless board.
Dec 29, 2009 | HP Pavilion dv6000z Notebook
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network Tasks..click..Create A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
WHAT PCI CARD TO GET WIRELESS INTERNET ACCESS ON
You can get this adapter from Linksys its WMP54G so you can make the computer wireless, but you can also check some adapter from Ntegear , Belkin and Dlink...
Aug 16, 2009 | HP Pavilion 734n PC Desktop
HP Pavilion a330n (Refurbished) (RBDM169AR) PC Desktop Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
